Error Causing HS3 to Shut Down
  • Error Causing HS3 to Shut Down
    I posted this in the HS3 board and someone I suggested I post it over here. My HS3 is shutting down on its own and the logs seem to point to a JowiHue issue. And the update did not seem to help. Still having HS3 shut down on its own.
    ___________________________________________________________
    Thanks for the response. Looks like it shut down last night. Here are the errors. There are six events and the below is from earliest to latest. Looks like it was JowieHue and I do show an update needed for that PlugIn so I will update it and see if that helps.
    <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
    - <System>
    <Provider Name=".NET Runtime" />
    <EventID Qualifiers="0">1026</EventID>
    <Level>2</Level>
    <Task>0</Task>
    <Keywords>0x80000000000000</Keywords>
    <TimeCreated SystemTime="2018-06-23T07:58:50.035549400Z" />
    <EventRecordID>3338</EventRecordID>
    <Channel>Application</Channel>
    <Computer>HPPav</Computer>
    <Security />
    </System>
    - <EventData>
    <Data>Application: HSPI_JowiHue.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.NullReferenceException at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(System.Runtime.Remoting.Messa ging.IMessage) at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Syst em.Runtime.Remoting.Proxies.MessageData ByRef, Int32) at HomeSeerAPI.IHSApplication.WriteLog(System.String, System.String) at HSPI_JowiHue.utils.Log(System.String, LogLevel) at HSPI_JowiHue.HueTools.UpdateStatusTimer() at HSPI_JowiHue.HueTools+_Closure$__._Lambda$__R80-3(System.Object) at System.Threading.TimerQueueTimer.CallCallbackInContext(Syste m.Object) at System.Threading.ExecutionContext.RunInternal(System.Threadi ng.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.ExecutionContext.Run(System.Threading.Execu tionContext, System.Threading.ContextCallback, System.Object, Boolean) at System.Threading.TimerQueueTimer.CallCallback() at System.Threading.TimerQueueTimer.Fire() at System.Threading.TimerQueue.FireNextTimers() at System.Threading.TimerQueue.AppDomainTimerCallback()</Data>
    </EventData>
    </Event>
    - <System>
    <Provider Name="Application Error" />
    <EventID Qualifiers="0">1000</EventID>
    <Level>2</Level>
    <Task>100</Task>
    <TimeCreated SystemTime="2018-06-23T07:58:50.231545900Z" />
    <EventRecordID>3339</EventRecordID>
    <Security />
    </System>
    - <EventData>
    <Data>HSPI_JowiHue.exe</Data>
    <Data>2.0.2.3</Data>
    <Data>5af1f1ee</Data>
    <Data>mscorlib.ni.dll</Data>
    <Data>4.7.3110.0</Data>
    <Data>5ae8c225</Data>
    <Data>c0000005</Data>
    <Data>00433e72</Data>
    <Data>4494</Data>
    <Data>01d40a9254607663</Data>
    <Data>C:\Program Files (x86)\HomeSeer HS3\HSPI_JowiHue.exe</Data>
    <Data>C:\WINDOWS\assembly\NativeImages_v4.0.30319_32\mscor li b\a5805dd044dd9d13b4349c862f767035\mscorlib.ni.dll</Data>
    <Data>5c0a3d7f-aee6-43c3-b905-e96931cd4d36</Data>
    <Data />
    <Data />
    </EventData>
    </Event>
    - <Event xmlns="http://schemas.microsoft.com/win/2004/08/events/event">
    - <System>
    <Provider Name="Windows Error Reporting" />
    <EventID Qualifiers="0">1001</EventID>
    <Level>4</Level>
    <Task>0</Task>
    <TimeCreated SystemTime="2018-06-23T07:58:53.550503600Z" />
    <EventRecordID>3340</EventRecordID>
    <Security />
    </System>
    - <EventData>
    <Data>1527931383357000374</Data>
    <Data>5</Data>
    <Data>CLR20r3</Data>
    <Data>Not available</Data>
    <Data>0</Data>
    <Data>mscorlib</Data>
    <Data>5b6f</Data>
    <Data>13</Data>
    <Data>System.NullReferenceException</Data>
    <Data />
    <Data>\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERC76 E. tmp.dmp \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCC22.tmp.WE RInternalMetadata.xml \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCC52.tmp.xm l \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCC50.tmp.cs v \\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERCCAF.tmp.tx t</Data>
    <Data>C:\ProgramData\Microsoft\Windows\WER\ReportArchive\A pp Crash_HSPI_JowiHue.exe_f8415591f9b5df974f491d6c521bdae9dfafb 5_e4965090_02c3d355</Data>
    <Data />
    <Data>0</Data>
    <Data>268435456</Data>
    <Data>8c69e611d8945573d5344d7f722a4ab6</Data>
    <Data>0</Data>
    </EventData>
    </Event>
    - <System>
    <Provider Name="ASP.NET 4.0.30319.0" />
    <EventID Qualifiers="49152">1325</EventID>
    <Level>2</Level>
    <Task>0</Task>
    <TimeCreated SystemTime="2018-06-23T08:00:57.340911300Z" />
    <EventRecordID>3341</EventRecordID>
    <Security />
    </System>
    - <EventData>
    <Data>An unhandled exception occurred and the process was terminated. Application ID: 9398e23e Process ID: 2716 Exception: System.OutOfMemoryException Message: Exception of type 'System.OutOfMemoryException' was thrown. StackTrace:</Data>
    </EventData>
    </Event>
    - <System>
    <Level>2</Level>
    <Task>0</Task>
    <TimeCreated SystemTime="2018-06-23T08:05:15.275594100Z" />
    <EventRecordID>3342</EventRecordID>
    <Security />
    </System>
    - <EventData>
    </EventData>
    </Event>
    - <System>
    <Level>2</Level>
    <Task>0</Task>
    <TimeCreated SystemTime="2018-06-23T08:05:15.276593400Z" />
    <EventRecordID>3343</EventRecordID>
    <Security />
    </System>
    - <EventData>
    <Data>Application: HS3.exe Framework Version: v4.0.30319 Description: The process was terminated due to an unhandled exception. Exception Info: System.OutOfMemoryException</Data>
    </EventData>
    </Event>
    - <System>
    <Level>2</Level>
    <Task>100</Task>
    <TimeCreated SystemTime="2018-06-23T08:05:15.745587300Z" />
    <EventRecordID>3344</EventRecordID>
    <Security />
    </System>
    - <EventData>
    <Data>HS3.exe</Data>
    <Data>3.0.0.435</Data>
    <Data>5ada0565</Data>
    <Data>KERNELBASE.dll</Data>
    <Data>10.0.17134.112</Data>
    <Data>c863c6f9</Data>
    <Data>e0434352</Data>
    <Data>0010db52</Data>
    <Data>a9c</Data>
    <Data>01d40a9252ba9036</Data>
    <Data>C:\Program Files (x86)\HomeSeer HS3\HS3.exe</Data>
    <Data>C:\WINDOWS\System32\KERNELBASE.dll</Data>
    <Data>6cec1c77-1b13-4322-a9ed-159edc4149e4</Data>
    <Data />
    <Data />
    </EventData>
    </Event>
    pcourt,
    You are not the first seeing this confusing issue.
    It is HS3 going down, because of that the JowiHue plugin has to close as well (check this part in the error messages: "JowiHue.HueTools+_Closure$__._Lambda$__")
    This seem to alwasy happen when HS3 stops comunicating all of the sudden. Why HS3 is canceling is the issue to find here....
    Sorry, but the issue is not with the plugin.
    Wim
    -- Wim
