Issues with deConz
  • Issues with deConz
    I just found this while messing around with some EasyTrigger Device Groups and I verified outside of EasyTrigger as well.
    Setup:
    Windows 10 Pro
    deConz 2.05.20
    ConBee stick
    HS3 .449
    Lights: Osram/Sylvania Color LEDVANCE A19
    Scenario:
    functions from main interface work fine. In events if I set the event to on/off things work. If I set to a percentage in the drop down the lights do not turn on.
    Found this when setting an EasyTrigger group to 100 and nothing happened. I started checking and found that the same event works when set to turn the device on but not to a value.
    Setup:
    Windows 10 Pro
    deConz 2.05.20
    ConBee stick
    HS3 .449
    Scenario:
    John, I wonder if it would make any difference if you upgraded deconz to 2.0.5.32? https://www.dresden-elektronik.de/deconz/win/
      I wasn't checking their beta site. I'll try the new release.
        Jeubanks,
        Let me know if the new version helps you, otherwise I will look if I can emulate what I think easytrigger is doing(which should just be a setdevicevalue)?
        Wim
        -- Wim
