Error Parameter name: bindingFlags when taking scene snapshot
  • Error Parameter name: bindingFlags when taking scene snapshot
    Hi Wim,
    I was trying to create some scenes using the scene snapshot function.
    Unfortunately, it does not seem to work.
    I tried to catch the errror message I receive. added below.
    Workaround is to manually fill in the hue/sat values from the lights I am taking the snapshot.
    I am using hs3linux beta version 459 on mono version 5.0.1.1
    philips bridge version is 1, the old version.
    Zigmund
    Jul 22 13:26:43 hs3 mono[26843]: 01:26:43:6482:[JowiHue]->Error: (SceneSnapshot)::No arguments can be provided to Get a field value.
    Jul 22 13:26:43 hs3 mono[26843]: Parameter name: bindingFlags
    Jul 22 13:27:17 hs3 mono[26843]: 01:27:17:5086:[JowiHue]->Debug: (postBackProc) :Config:Debug: checked
    Jul 22 13:27:17 hs3 mono[26843]: 01:27:17:5101:[JowiHue]->Debug: (postBackProc) :Config:id: Debug
    Jul 22 13:27:22 hs3 mono[26843]: 01:27:22:4964:[JowiHue]->Error: (SceneSnapshot)::No arguments can be provided to Get a field value.
    Jul 22 13:27:22 hs3 mono[26843]: Parameter name: bindingFlags
    Jul 22 13:27:45 hs3 mono[26843]: 01:27:45:5983:[JowiHue]->Debug: (postBackProc) :oTabTraces
    Jul 22 13:27:45 hs3 mono[26843]: 01:27:45:5995:[JowiHue]->Debug: (postBackProc) :Config:oTabs: oTabTraces
    Jul 22 13:27:45 hs3 mono[26843]: 01:27:45:6005:[JowiHue]->Debug: (postBackProc) :Config:id: oTabTraces
    Jul 22 13:27:46 hs3 mono[26843]: 01:27:46:9117:[JowiHue]->Debug: (postBackProc) :Config:id: timer
