Problem installing the plugin
  • Almighty
    Yes, I can confirm, that after setting decimal point back to "," everything is working fine. So I won't be needing the initilad db, thanks.
    Every of my attempts was with fresh installation of the plugin, I was having troubles getting the devices from deCONZ to HS, that's why I tried to rebuild the deCONZ network (unnecessary, I know now). It's possible that the problem was caused by something else, but I don't remember doing anything else, other than uninstalling plugin, changing the separator, and installing it again.
    Thanks for your time, I'll post update in case something weird happens.
  • w.vuyk
    I don't see anything regarding the decimal point yet here.
    But I think that you maybe started the plugin for the first time? "Table SensorType has been altered" is suggesting this? In that case I think I need to update the initial database, as it seems the plugin starts a conversion and the sequence of (the several conversion) is throwing errors?
    The issue "Odkaz na objekt není nastaven na instanci objektu" (thanks for translating ) is a missing column and as of this error the table sensormodels is not created anymore. With the second start this is corrected as the plugin has done some conversions already.
    I will update the initial database so this error will be prevented. I think if you revert the decimal point settings all will be normal again (but stop HS3 during the revert)
    If it does not work, send me a PM with your mail address so I can send you a new initial database.
    As an extra there should normally never be a reason to remove or reinstall deCONZ for the plugins errors, or I would advise for it
    Wim
  • Almighty
    Ok, sorry about not providing detailed information. I just replied, because changing the decimal separator fixed my issue and also SensorModels table was mentioned in the log. There was indeed no exception regarding number parsing exception, and since I reinstalled deConz and your plugin several times (including re-binding all the devices) before that, I was glad that it's working and didn't investigate what the cause was.
    My version is 2.0.3.3
    Here is log from that moment:
    10:35 - is the installation attempt with the "," decimal separator
    10:43 - is after the change to "." (list of added devices goes on, but trimmed it)
    "Odkaz na objekt není nastaven na instanci objektu" - is null reference exception in Czech.
    Jul-23 10:43:47 JowiHue 0 lights and/or plugs connected to bridge 'Phoscon-GW new'
    Jul-23 10:43:47 JowiHue 1 Groups available on bridge 'Phoscon-GW new'
    Jul-23 10:43:47 JowiHue Bridge Phoscon-GW new is at version 2.5.66 of type deCONZ on a ConBee II
    Jul-23 10:43:47 JowiHue 4 Temperature sensor found on bridge 'Phoscon-GW new'
    Jul-23 10:43:47 JowiHue 1 Daylight sensor found on bridge 'Phoscon-GW new'
    Jul-23 10:43:47 JowiHue 1 Open/Close sensor found on bridge 'Phoscon-GW new'
    Jul-23 10:43:47 JowiHue 4 Humidity sensor found on bridge 'Phoscon-GW new'
    Jul-23 10:43:47 JowiHue 4 Pressure sensor found on bridge 'Phoscon-GW new'
    Jul-23 10:43:47 JowiHue -------------------------------------Plugin info ---------------------------------------------
    Jul-23 10:43:47 JowiHue 22 Presets available for use in the JowiHue plugin
    Jul-23 10:43:47 JowiHue 0 Local scenes available for use in the JowiHue plugin
    Jul-23 10:43:47 JowiHue 0 Animations available for use in this plugin
    Jul-23 10:43:46 JowiHue * Connected to bridge Phoscon-GW new at 192.168.1.98:8080
    Jul-23 10:43:45 JowiHue Importing SensorModels
    Jul-23 10:43:45 JowiHue Importing SensorTypes
    Jul-23 10:43:45 JowiHue Importing lampTypes
    Jul-23 10:43:45 JowiHue InitIO:Plugin basic initialisation done
    Jul-23 10:43:45 JowiHue ****** Creating table SensorModels
    Jul-23 10:43:45 JowiHue Starting plugin JowiHue 2.0.3.3 on Windows
    Jul-23 10:40:05 JowiHue disconnecting bridge Phoscon-GW new
    Jul-23 10:40:05 JowiHue JowiHue Plugin is stopped. Thanks for using it :-)
    Jul-23 10:37:11 JowiHue Scanning New sensors started. If New lights are found the plugin will add them automatically
    Jul-23 10:35:52 JowiHue Error: (BuildSliderSensors):Start:web Maintenance:Odkaz na objekt není nastaven na instanci objektu.
    Jul-23 10:35:37 JowiHue Refresh bridge Phoscon-GW new set to 30 seconds after establishing direct connection
    Jul-23 10:35:36 JowiHue socket opened for Phoscon-GW new on 192.168.1.98:443
    Jul-23 10:35:35 JowiHue Warning: Bridge registered, device already present - updating device
    Jul-23 10:35:33 JowiHue Group Office devices have been cleared
    Jul-23 10:35:33 JowiHue Warning: Group Office was removed from bridge, clearing devices
    Jul-23 10:35:33 JowiHue Registration of bridge was succesfull
    Jul-23 10:35:24 JowiHue Info: -- Unregistered bridge found on network at 192.168.1.98
    Jul-23 10:35:24 JowiHue InitPlugin:No registered bridge found; please register a bridge through the configuration page
    Jul-23 10:35:13 JowiHue Bridge Phoscon-GW lost its registration. Please reregister.
    Jul-23 10:35:13 JowiHue Warning: SetLightSuspected: Bridge has been reset, setting all bridge lights suspected, so original settings can be restored later if needed
    Jul-23 10:35:13 JowiHue * Connected to bridge Phoscon-GW at 192.168.1.98:8080
    Jul-23 10:35:13 JowiHue Error: (UpdateSensorModels)::SQL logic error or missing database no such table: SensorModels
    Jul-23 10:35:13 JowiHue Error: (UpdateSensorTypes)::constraint failed column Type is not unique
    Jul-23 10:35:13 JowiHue Importing SensorModels
    Jul-23 10:35:13 JowiHue Importing SensorTypes
    Jul-23 10:35:13 JowiHue InitIO:Plugin basic initialisation done
    Jul-23 10:35:13 JowiHue Importing lampTypes
    Jul-23 10:35:13 JowiHue Error: (InitDatabase)::Error occured at table SensorTypes with statement PRAGMA table_info(SensorTypes)
    Jul-23 10:35:13 JowiHue Error: (InitDatabase)::Odkaz na objekt není nastaven na instanci objektu.
    Jul-23 10:35:13 JowiHue Table SensorType has been altered
    Jul-23 10:35:13 JowiHue Starting plugin JowiHue 2.0.3.3 on Windows
  • w.vuyk
    I doubt if you are seeing the same issue here unless you are running a very old version of the plugin. The SQL column that caused the issue here has been converted last year, It is no longer holding a decimal point?
    Wim
  • Almighty
    I also confirm this problem. I had to change the decimal separator as well, to make it work. Feels like Win95 times again...
    I really like this plugin, but the time spent with this unexpected troubleshooting increases its price, so it would be nice to fix all the culture specific things to invariant culture, so the user doesn't have to change his habits and needs.
  • chapa
    I confirm it was the problem.
    Changed number formatting to US and reinstalled the plugin, all okay
    It will be good plugin to be aware of region settings.
    Decimal and currency separators and formats, as I would like to keep them in my flavor and meantime use the plugin
    Thanks.
  • chapa
    One idea I just came with...could it be some Windows Regional Options I changed?
    Something like hardcoded decimal separator and/or other formats used when building sql statements?
    "Couldn't store <0,45> in StandbyPower Column. Expected type is Double."
    Decimal point like "0.45" is set as windows number decimal symbol, and from the log it is trying "0,45"
    Maybe I should try to resume all Windows regional settings, but I can not remember default ones...
  • chapa
    I just did what you recommended.
    All database folder permissions are ok.
    I stopped and removed the plugin, than reinstalled it.
    This is from the log:
    юли-24 18:53:14 JowiHue * Connected to bridge Philips hue at 192.168.1.154:80
    юли-24 18:53:13 JowiHue Error: (UpdateSensorModels)::SQL logic error or missing database no such table: SensorModels
    юли-24 18:53:13 JowiHue Importing SensorModels
    юли-24 18:53:13 JowiHue Error: (UpdateSensorTypes)::constraint failed column Type is not unique
    юли-24 18:53:13 JowiHue Importing SensorTypes
    юли-24 18:53:13 JowiHue Error: (UpdateLampTypes)::constraint failed column ModelID is not unique
    юли-24 18:53:13 JowiHue Importing lampTypes
    юли-24 18:53:13 Starting Plug-In Plugin JowiHue started successfully in 607 milliseconds
    юли-24 18:53:13 JowiHue InitIO:Plugin basic initialisation done
    юли-24 18:53:13 JowiHue Error: (InitDatabase)::Input string was not in a correct format.Couldn't store <0,45> in StandbyPower Column. Expected type is Double.
    юли-24 18:53:13 JowiHue Error: (InitDatabase)::Error occured at table LampTypes with statement select * from LampTypes
    юли-24 18:53:12 JowiHue Starting plugin JowiHue 2.0.2.5 on Windows
    юли-24 18:53:12 Starting Plug-In Initializing plugin JowiHue ...
    юли-24 18:53:12 Info Plugin JowiHue has connected. IP:127.0.0.1:55345
    юли-24 18:53:11 Plug-In Finished initializing plug-in JowiHue
    юли-24 18:53:06 Z-Wave Device: Node 9 Z-Wave Sensor Binary Set to On/Open/Motion
    юли-24 18:53:05 Z-Wave Device: Node 9 Z-Wave Home Security Set to NOTIFICATION for type Home Security, Event: Motion Detected
    юли-24 18:52:22 Updater Install/Update of package JowiHue was successful.
    юли-24 18:52:22 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_JowiHue.exe.config
    юли-24 18:52:22 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\JowiHue\WebSocket4Net.dll
    юли-24 18:52:22 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\JowiHue\Newtonsoft.Json.dll
    юли-24 18:52:22 Updater Extraction Complete.
    юли-24 18:52:21 Updater Extracting files from zip file: JowiHue_images.zip
    юли-24 18:52:21 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\Data\JowiHue\JowiHue.db
    юли-24 18:52:21 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\Config\JowiHueImports.xml
    юли-24 18:52:21 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\jowihue\JowiHue.pdf
    юли-24 18:52:21 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\Docs\JowiHue.pdf
    юли-24 18:52:19 Updater Installing package JowiHue
    юли-24 18:52:19 Updater Update hspi_jowihue.exe downloaded successfully
    юли-24 18:52:14 Updater Downloading update: JowiHue
    юли-24 18:52:14 Updater Starting download of updates
  • w.vuyk
    Could you check if the JowiHue.db file is reachable for the plugin? You can test this by logging in as the same user HS3 is running on. Then try to go to the directory of the databs ([hs3 install direcotry]\Data\JowiHue\JowiHue.db. Try to create a new file here and remove it.If this works, disable the plugin and remove the JowiHue.db. Then reinstall the plugin through the manage plugin page.
    If you restart the plugin after that, you have to reregister the bridge, but the devices should still match. Do you then stil see those errors?
    Wim
  • chapa
    started a topic Problem installing the plugin
    Hello,
    I just purchased JowiHue plugin.
    I have troubles running it.
    I can not get my Philips Hue lights added as devices and control them as expected.
    Attaching different logs stating some SQLite errors like:
    1. 22.7.2018 г. 22:21:43 ~!~JowiHue~!~Error: (InitDatabase)::Error occured at table LampTypes with statement select * from LampTypes
    2. SQLite error (2067): abort at 20 in [INSERT INTO [main].[LampTypes]...
    Can someone please assist me with the problem?
    HS Details:
    Operating System: Microsoft Windows 10 Home - Work Station
    Number of Devices: 35
    Number of Events: 1
    Available Threads: 200
    HSTouch Enabled: True
    Event Threads: 0
    Event Trigger Eval Queue: 0
    Device Exec Queue: 0
    HSTouch Event Queue: 0
    Email Send Queue: 0
    Anti Virus Installed: Windows Defender
    License: Registered
    Web Server Port: 80
