ZGPSWITCH_large_small.png - anyone got this picture?
  • ZGPSWITCH_large_small.png - anyone got this picture?
    So I have this minor warning in the logfile:
    Warning File does not exist: /opt/HomeSeer/html/images/JowiHue/ZGPSWITCH_large_small.png
    Does anyone know where to find this missing file?
    Can you tell me for wich device this image is used? Might be a bit hard to find, but it would help me why the plugin is expecting this file. Probably a bug.
    Wim
    -- Wim
      This is from the Philips Tap Switch:
      https://www2.meethue.com/en-us/p/hue...h/046677456696
        You could change it to Hue_Tap in the images/jowihue directory. Or do a save as on the hue_tap as the other name until Wim can look into it.
          Yes that kind of worked:
          /opt/HomeSeer/html/images/JowiHue> cp Hue_Tap_Large.png ZGPSWITCH_large.png
          /opt/HomeSeer/html/images/JowiHue> cp Hue_Tap.png ZGPSWITCH_large_small.png
            I seem to be missing yet another file:
            /opt/HomeSeer/html/images/JowiHue/JowiHueBridgeLarge_small.png
            After reboot....
              After reboot....
              Are you referring to deconz? Or something else like the conbee?
                Not sure I follow... I do use a DeConz software and stivk maybe conbee cant say from where I am currently.
                The warning is from within JowoHue, so?
                  It is looking for a png file of some bridge, yes? The bridges or hubs used with jowihue are the conbee, RP2,3 and the philips hue bridge. Can you give a little more detail as to where this error is occurring?
                    Well I guess that it is ConBee then.
                    The warning is from HS3 log file, after boot, could be somewhere between JoeiHue is disconnected from DEConz, and the during connection (I have minor problem with autostart DEConz). I just guessing, but something like that...
                      Here is a png of conbee if you want to use it. Are you starting Deconz before HS3? That is the best way. What port is deconz on?
                        The setup was, and should still have been - just don't work for some unknown reason, autostart virtual servers in specific order. So I always have to start DeConz the hard way (manually after logging into the server). I have not changed the portnumber as far as I know, so DeConz uses default - what ever that is.
                          In the end I did:
                            In file explorer go to view and select show hidden files. Create a shortcut on your desktop and follow the path back until you find deCONZ.exe. At the end of the exe put a space and this --http-port=93 This is an empty port so should work. I used it. Close deconz and HS. Use the shortcut you just made and open deconz and then HS. Check in deconz on the upper left on the one that has API in it (can't remember name) and see if it reads port 93. If it does you are good and it will stay 93 as long as you don't shut down deconz. If you do shutdown deconz then use the same shortcut to open it first the HS.
                            C:\Users\some name\AppData\Local\deCONZ\bin\deCONZ.exe --http-port=93
                            (some name) is your path to AppData
                              Why change port?
                              Brw I use Linux Ubuntu, so desktop and shortcuts... Softlinks yes. And I run headless...
