New Error Showing Up in Jowihue
  • New Error Showing Up in Jowihue
    I am seeing this error show up quite frequently (every hour) now in the HS log.
    Aug-27 7:50:44 AM JowiHue Error: (CheckBridgeUpdate)::Object variable or With block variable not set.
    Aug-27 7:50:44 AM JowiHue Error: (CheckBridgeUpdate)::CheckBridgeUpdate Version 1.26.0
    Larry,
    I am gussing you ahve a Philips bridge still active? there is a new version API available, 1.27. But Philips has changed the upgrade procedures, so I am gussng the plugin does not like it. Here I had to upgrade using the Philips app and restarting the plugin... I will check if I can reintegrade this in the the plugin.
    Wim
    -- Wim
      Wim, how did you go about updating the API. I have auto update enabled in the app but there is no API to select.
        I have auto update disabled here, opened up the app and it told me there was an update?
        -- Wim
          Under the 'About' selection in the App it reads "Philips Hue Version:1806051111 and "Hue" at the top of same page reads Version 3.4.0 (6280)
          Is this what you have? I do not see anything related to 1.27.
            Larry,
            I had forgotten to think I am a beta tester for Philips. So my api is different from yours and because of that also am having a different version of the software. Sorry for that confusion!
            Can you send me a detailed trace for this error? Make sure you restart the plugin after setting the trace option, I will need to look at this from the start of the plugin.
            Wim
            -- Wim
              Larry,
              Wim
              Wim, sent you a PM on the error. It appears to have stopped for now. I will monitor the HS log and see if it returns.
                Larry,
                Ok, I will try and repair the update proces anyway, it is not working at the moment.
                -- Wim
                  Hi there:
                  New Homeseer user here and also first post on the forum! I, too, am seeing this error every hour:
                  Sep-04 5:41:59 PM JowiHue Error: (CheckBridgeUpdate)::Object variable or With block variable not set.
                  Sep-04 5:41:59 PM JowiHue Error: (CheckBridgeUpdate)::CheckBridgeUpdate Version 1.26.0
                  Just wanted to add another data point to the conversation. Please let me know how else I can help.
                  Ragato
