Ip change all the time.
  • Ip change all the time.
    Hi,
    The connection seems to always connect and disconnect with phoscon . Somebody knows how to prevents that ? Thanks
    Sep-05 5:18:01 PM JowiHue Device created for sensor Multi Sensor on bridge Phoscon-GW with ID 4
    Sep-05 5:18:01 PM JowiHue Device created for sensor Multi Sensor on bridge Phoscon-GW with ID 3
    Sep-05 5:18:01 PM JowiHue Device created for sensor Window / Door Sensor on bridge Phoscon-GW with ID 2
    Sep-05 5:18:01 PM JowiHue socket closed for bridge Phoscon-GW on 192.168.1.3:443
    Sep-05 5:18:01 PM JowiHue disconnecting brige Phoscon-GW
    Sep-05 5:18:01 PM JowiHue Warning: Bridge Phoscon-GW changed IP from 192.168.1.3:8081 to 127.0.0.1:8081 - Restarting processes for this bridge
    Sep-05 5:13:31 PM JowiHue socket opened for Phoscon-GW on 192.168.1.3:443
    Sep-05 5:13:01 PM JowiHue socket closed for bridge Phoscon-GW on 192.168.1.3:443
    Sep-05 5:13:01 PM JowiHue disconnecting brige Phoscon-GW
    Sep-05 5:13:01 PM JowiHue Warning: Bridge Phoscon-GW changed IP from 192.168.1.3:8081 to 127.0.0.1:8081 - Restarting processes for this bridge
    Sep-05 5:08:31 PM JowiHue socket opened for Phoscon-GW on 192.168.1.3:443
    Sep-05 5:08:01 PM JowiHue socket closed for bridge Phoscon-GW on 192.168.1.3:443
    Sep-05 5:08:01 PM JowiHue disconnecting brige Phoscon-GW
    Sep-05 5:08:01 PM JowiHue Warning: Bridge Phoscon-GW changed IP from 192.168.1.3:8081 to 127.0.0.1:8081 - Restarting processes for this bridge
    Sep-05 5:03:31 PM JowiHue socket opened for Phoscon-GW on 192.168.1.3:443
    Sep-05 5:03:01 PM JowiHue socket closed for bridge Phoscon-GW on 192.168.1.3:443
    Sep-05 5:03:01 PM JowiHue disconnecting brige Phoscon-GW
    Sep-05 5:03:01 PM JowiHue Warning: Bridge Phoscon-GW changed IP from 192.168.1.3:8081 to 127.0.0.1:8081 - Restarting processes for this bridge
    Sep-05 4:57:51 PM JowiHue socket opened for Phoscon-GW on 192.168.1.3:443
    that is the same ip in theory, since phoscon is on the same machine as hs3... i'm kind of confuse..lol
      I installed phoscon with this docker image here : https://github.com/marthoc/docker-deconz
      with those settings :
      docker run -d \
      --name=deconz \ --net=host \
      -e DECONZ_WEB_PORT=8081 \
      -e DECONZ_WS_PORT=443 \
      --restart=always \
      -v /opt/deconz:/root/.local/share/dresden-elektronik/deCONZ \
      --device=/dev/ttyUSB0 \
      marthoc/deconz
      EDIT:
      Redone my docker image and
      removed the line
      Since it already port 443 by default...
      It seems to do the tricks... we'll see.
      I'll report here if there's a problem
        Just as a remark, naming your gateway "Phoscon" might be confusing. Phoscon is the web app that points to deCONZ, the software that controls the ZigBee stack. The gateway is really deCONZ.
        The Phoscon Webapp allows you to control the deCONZ, deCONZ controls the lights and sensors. Theoretically you would not need Phoscon at all with the plugin (but might be handy now and then!)
        Wim
        -- Wim
          Haaa, Thanks for this. Now i have the choice.
          But since it take so little of my pc ressources i'll keep it just in case :P
