Xiaomi vibration sensor
    Has anyone gotten ok one of these to work in HS? I have lots of uses for these and they are on sale for $8 shipped from gearbest this week..
    Mike
    Looks interresting.
    Wunder if DeConz has this one working yet and what data to get from it.
    Sent from my iPhone using Tapatalk Pro
      It seems that deCONZ is already supporting it... https://github.com/dresden-elektroni...gin/issues/748
      Will be ordering too and see if the plugins need to be updated. If one of you receive them earlier, let me know if the plugin adds the device?
      Wim
      -- Wim
        Wim
        Will do.
          It does add it, but not quite supported methinks:
Name:	Screenshot 2018-11-09 at 20.44.58.png
            The values are not known yet by the plugin, but that can be changed quite easy. the value you are seeing has to be translated to the motion.....
            Can you post the JSON that is shown on the parent device properties (JowiHue tab)? That will help me in adding the device and next I should find the possible values and the motions - I know there are seperate values for left/right shaking, up/down shaking and I beleive circular shaking?
            This is going to work quite easy I am sure!
            Wim
            -- Wim
              Is it this?
              ZHASwitch
              **************************** Object info *****************************
              "ep": 1,
              "etag": "18db5da8624f9f879271b5a4855a3e5d",
              "mode": 1,
              "state": {
              "buttonevent": 1007,
              "lastupdated": "2018-10-28T12:26:15"
              "config": {
              "on": true,
              "battery": 95,
              "reachable": true
              "name": "lumi.vibration.aq1",
              "type": "ZHASwitch",
              "modelid": "lumi.vibration.aq1",
              "manufacturername": "LUMI",
              "uniqueid": "00:15:8d:00:02:a5:1f:89-01-0101"
              ************************* End Object info ***************************
                That is it... Will work on that.
                Does the value of the device change when you make it vibrate in any way?
                -- Wim
                  1007 Shake
                  1008 Drop
                  1009 Tilt
                  See: https://github.com/dresden-elektroni...gin/issues/748
                    Thanks!
                    Attached is an updated JowiHueImports.xml. Place this file in the \Config directory of your HS3 installation. Then check the log, within 30 minutes the plugin should see the file and import it. Once this is done, go to the parent device of the vibration sensor and opn properties. On the JowiHue tab, press the button "Rebuild device values". From there the status of the device should show with logical description?
                    Wim
                    -- Wim
                      Will try.
                        Seems to work
Name:	Screenshot 2018-11-11 at 15.04.14.png
                          Great!! Thanks!
                          -- Wim
                            This is great!
                            Can you program the sensitivity levels? You are supposed to be able to set the sensitivity of the sensor to low, medium and high.
                            thx
                            mike
                              Mike,
                              No, not yet as it is not implemented in the REST API. The developers are still looking into it, but it might not be possible. It seems to be complicated so far. But if they are going to support it, I will implement it in the plugin as wel.
                              Wim
                              -- Wim
