If this is your first visit, be sure to check out the FAQ. You must register before you can post. Your first post will be checked for appropriate content
(SPAM) - please allow a bit of time for that. After that, you'll be able to post at will!
On github this issue was reported also few days ago. I believe they will change this behaviour by resetting the vibration strength. Not sure if this is already done in the latest version.
Voila! 66 seconds after movement, it said no movement! I have mine positioned upside down attached to the washing machine body so I'm not expecting Orientation to change,
How do you get to see all these values in HS3 lke tilt angle and stuf? I get only this:
Phoscon version 2.05.77 FW:26350500
jowihue version 2.1.1.0
Phoscon does not display all of that info that I am aware of, at least it doesn't for me. There are two possibilities, both are fixable. One is that deCONZ did not fully discover the device, or it was discovered before deCONZ was aware of all of the capabilities. Or, the same for JowiHue, the device was added before JowiHue was aware of how to define it. Or both.
In the JowiHue tab for the vibration device, what is in the JSON? Scroll down to see it. Copy and paste that in a message and we can look at it. If it does not have all of the information, then you will need to rediscover the device in deCONZ. Don't delete it in deCONZ or Phoscon, just search for a new sensor in Phoscon and push the button on the sensor until it blinks. Wait a minute or so.
Either way, disable JowiHue, delete the two HS devices, and enable JowiHue and all the correct devices should be created. I had to do both of these things because I added it before it was fully supported.
The last update of the vibration sensor is from a few days back (2020-07-01) you did not move the sensor since then, or was it not seen by deCONZ anymore since then?
Did you try resetting the device like Bill was suggesting to you? Start a search for devices in the JowiHue configuration and press the small button on the vibration sensor until the blue light blinks? Can you confirm this?
Did you try and disable the plugin and delete the vibration device from the HS3 devicelist like Bill asked? What happens if you then restart the plugin?
