new alarm device on xiaomi aquara motion sensor
    #16
    yes that's weird.
    i checked my locale on my server , it is good . Same thing in phoscon.
    locale
    LANG=en_CA.UTF-8
    LANGUAGE=
    LC_CTYPE="en_CA.UTF-8"
    LC_NUMERIC="en_CA.UTF-8"
    LC_TIME="en_CA.UTF-8"
    LC_COLLATE="en_CA.UTF-8"
    LC_MONETARY="en_CA.UTF-8"
    LC_MESSAGES="en_CA.UTF-8"
    LC_PAPER="en_CA.UTF-8"
    LC_NAME="en_CA.UTF-8"
    LC_ADDRESS="en_CA.UTF-8"
    LC_TELEPHONE="en_CA.UTF-8"
    LC_MEASUREMENT="en_CA.UTF-8"
    LC_IDENTIFICATION="en_CA.UTF-8"
    LC_ALL=
    xxxx@Automation:~# cat /etc/timezone
    America/Toronto
      #17
      So...since phoscon is just a getting data from deconz.
      This is a deconz or a jowihue plugin issue.
        #18
        The json that the JowiHue plugin displays is the raw data from the deCONZ REST api, that is where the date/time come from. I looked at mine and the time is GMT.
        I have two of the motion sensors without the aq2, and one with. None of them have an alarm device defined.
        So I played around in the deCONZ gui with reading the individual items in the Basic cluster for the aq2 sensor. And I think it was software build that triggered a change, and the alarm device got added. So it looks like deCONZ is not always discovering all of the Basic cluster information, but when it does, it creates an alarm device.
          #19
          ok was able to change the locale time to
          "timezone": "America/Montreal"
          with this via postman
          http://dresden-elektronik.github.io/...configuration/
          I do not know if it will change something
            #20
            here is what the deconz rest api return now, after rebooting my server( I removed useless data) :
                "UTC": "2019-03-06T08:30:35",
                "linkbutton": false,
                "localtime": "2019-03-06T03:30:35",
                "timeformat": "24h",
                "timezone": "America/Montreal",
            And here is what i get from a jowi sensor that the status has been updated:
            **************************** Object info *****************************
            "state": {
            "presence": false,
            "lastupdated": "2019-03-06T08:25:30"
            "config": {
            "on": true,
            "battery": 100,
            "duration": 115,
            "reachable": true
            "name": "Bedroom poll xiaomi wall motion",
            "type": "ZHAPresence",
            "modelid": "lumi.sensor_motion.aq2",
            "manufacturername": "LUMI",
            "swversion": "20170627",
            "uniqueid": "00:15:8d:00:02:f8:d8:16-01-0406",
            "ep": 1,
            "etag": "94739329b4361bf8d144e58727a5a0a4"
            ************************* End Object info ***************************
            Even if deconz had the wrong timezone ( now it is the good one), jowihue still has the wrong time for the ''lastupdated' ( the same time as the UTC variable in the json response from deconz api ).
            I do not know why ''localtime'' is not used
              #21
              I tried a get request to : MY_IP/api/my_app_KEY/sensors with postman.
              the response still has the wrong time. So this is not a jowihue issue :
              "name": "hue bedroom motion",
              "state": {
              "dark": true,
              "daylight": false,
              "lastupdated": "2019-03-06T08:46:04",
              "lightlevel": 0,
              "lux": 0
              "swversion": "6.1.0.18912",
              "type": "ZHALightLevel",
              I submitted a question to deconz github : https://github.com/dresden-elektroni...in/issues/1327
              edit :
              from this http://dresden-elektronik.github.io/...doc/schedules/
              it seems that the schedule function of deconz use the UTC time format. So I do not know why jowihue get the "lastupdated" from the sensors...?Maybe it is just useful for the author of this plugin , but meaningless for the user?
                #22
                The alarm sensors issue should be fixed in DeCONZ v.61
                  #23
                  Don't worry about the lastupdated field, it is only used by the plugin to check if there has been a change. The last change time of the HS3 device is what you should check and this works fine. the plugin thakes care of that.
                  I am hoping the extra alarm device will disappear, it has been there for quite some time already (4 months here I believe, and lastupdated stays at 'none' for that is there are no updates.
                  -- Wim
                    #24
                    Good news!!! First time i like errors logs
                    Apr-14 17:32:15 JowiHue Warning: Or remove the devices belonging to this sensor
                    Apr-14 17:32:15 JowiHue Warning: Did you remove a sensor from the bridge but left the HomeSeer devices? Re-add the sensor to the bridge and your events are save
                    Apr-14 17:32:15 JowiHue Warning: Orphaned Sensor Bathroom shelve motion (526) found, not found on any connected bridge
                    Apr-14 17:32:15 JowiHue Warning: Orphaned Sensor Xiaomi motion bedroom closet (516) found, not found on any connected bridge
                    Apr-14 17:32:15 JowiHue Warning: Orphaned Sensor Bedroom xiaomi wall motion (515) found, not found on any connected bridge
                    This mean, no more alarm sensor Devices
                    *****Just updated deconz to V63*****
