Over the past few days, I seem to have noticed a new problem using the JowiHue plugin. After enabling and initializing the plugin, the bridge is first reachable but then reports as being unreachable within the plugin within just a few seconds. This seems to be happening consistently. The bridge does have a DHCP reservation, so the network connectivity is consistent. I am always able to reach the Hue Bridge from the browser using both HTTP and HTTPS. I am also able to SSH to the HomeSeer box and then ping the Hue Bridge without any issues or latency whatsoever. Both devices are connected to the same Ubiquiti 24-port switch and ping times stay very consistent, so I feel confident that physical network connectivity is not a problem. Nobody is streaming unusual media traffic or transferring files over the network. And I can recreate this behavior every time the plugin starts up. My log file is posted below. Please let me know what else I should do to attempt to troubleshoot and resolve. Thanks in advance.
Jan-10 19:26:00 | JowiHue | Warning: Bridge Philips hue not reachable; SetLights canceled |
Jan-10 19:26:00 | Device Control | Device: Main Living Room Big Tall Lamp to Off (0) by/from: CAPI Control Handler |
Jan-10 19:25:57 | JowiHue | Warning: Bridge Philips hue not reachable; SetLights canceled |
Jan-10 19:25:56 | Device Control | Device: Main Living Room Big Tall Lamp to Off (0) by/from: CAPI Control Handler |
Jan-10 19:25:46 | JowiHue | ============================================================ ================================== |
Jan-10 19:25:46 | JowiHue | 0 Animations available for use in this plugin |
Jan-10 19:25:46 | JowiHue | 0 Local scenes available for use in the JowiHue plugin |
Jan-10 19:25:46 | JowiHue | 22 Presets available for use in the JowiHue plugin |
Jan-10 19:25:46 | JowiHue | -------------------------------------Plugin info --------------------------------------------- |
Jan-10 19:25:46 | JowiHue | 1 Generic status sensor found on bridge 'Philips hue' |
Jan-10 19:25:46 | JowiHue | 1 Daylight sensor found on bridge 'Philips hue' |
Jan-10 19:25:46 | JowiHue | 1 Remote switch(s) found on bridge 'Philips hue' with 1 supporting HS device(s) |
Jan-10 19:25:46 | JowiHue | 1 TAP(s) found on bridge 'Philips hue' with 1 supporting HS device(s) |
Jan-10 19:25:46 | JowiHue | Bridge Philips hue is at version 1810251352 of type BSB002 |
Jan-10 19:25:46 | JowiHue | 6 Groups available on bridge 'Philips hue' |
Jan-10 19:25:46 | JowiHue | 8 lights and/or plugs connected to bridge 'Philips hue' |
Jan-10 19:25:46 | JowiHue | -------------------------------------Bridge info --------------------------------------------- |
Jan-10 19:25:46 | JowiHue | HTTPS access enabled on bridge Philips hue |
Jan-10 19:25:43 | JowiHue | * Connected to bridge Philips hue at 10.1.0.58:80 |
Jan-10 19:25:41 | Plug-In | Finished initializing plug-in JowiHue |
Jan-10 19:25:41 | Starting Plug-In | JowiHue loaded in 1606 milliseconds |
