I have events that have worked for a long time. But since the 500 update and or the plugin update the hue doesnt work from events. I can change a light in the devices to a color and then run the event to an obvious different color and it doesnt change.
I am getting these entries non stop every few seconds
Here is the log when I ran the event
The event is attached as a photo. I only see three actions and I would have thought there should be 4? Is Hue missing?
Feb-21 19:50:13 | JowiHue | Debug: (UpdateSensor) :buttonevent enabled device updating, but value not present:Hue dimmer switch 1 |
Feb-21 19:50:10 | JowiHue | Debug: (UpdateSensor) :buttonevent enabled device updating, but value not present:Hue dimmer switch 1 |
Feb-21 19:50:58 | JowiHue | Debug: (UpdateSensor) :buttonevent enabled device updating, but value not present:Hue dimmer switch 1 |
Feb-21 19:50:55 | JowiHue | Debug: (UpdateSensor) :buttonevent enabled device updating, but value not present:Hue dimmer switch 1 |
Feb-21 19:50:52 | JowiHue | Debug: (UpdateSensor) :buttonevent enabled device updating, but value not present:Hue dimmer switch 1 |
Feb-21 19:50:52 | JowiHue | Debug: (SetDeviceByUserRequest) ::End |
Feb-21 19:50:52 | JowiHue | Saturation command send to Bedroom Lights (sat) |
Feb-21 19:50:52 | JowiHue | Debug: (SetDeviceByUserRequest) :SetDeviceByUserRequest:Start ref=59 Action:114 controltype:2 Controlstring: |
Feb-21 19:50:52 | JowiHue | Dim command send to Bedroom Lights |
Feb-21 19:50:52 | JowiHue | Debug: (SetDeviceByUserRequest) :SetDeviceByUserRequest:Start ref=57 Action:116 controltype:2 Controlstring: |
Feb-21 19:50:52 | JowiHue | Color temperatur command send to Bedroom Lights (CT) |
Feb-21 19:50:52 | JowiHue | Debug: (SetDeviceByUserRequest) :SetDeviceByUserRequest:Start ref=60 Action:187 controltype:2 Controlstring: |
Feb-21 19:50:52 | Event | Event Trigger "Master Bedroom on" |
Feb-21 19:50:52 | Event | Event Master Bedroom on triggered by the event page 'Run' button. |
Feb-21 19:50:49 | JowiHue | Debug: (UpdateSensor) :buttonevent enabled device updating, but value |
