Everything was working fine Friday, went away for the weekend came home, and the log was full of these errors.
Had to shut the Jowihue plugin down as it was filling up my log every minute with a long string of these errors.
Also tried:
- Turned the Jowihue plugin off.
- Rebooted the machine.
- Waited for deCONZ to see all the devices.
- Started the Jowihue plugin.
- And here is resulting log, minus many more similar entries.
Also tried:
- Scan device and scan sensors
- Rebuild values for both dvices and sensors
Mar-03 18:14:06 | JowiHue | ERROR!!! sensordevices NOT created, already present as 0 battery 0 |
Mar-03 18:14:06 | JowiHue | Warning: Cannot find ref 0 |
Mar-03 18:14:06 | JowiHue | Refresh bridge Phoscon-GW set to 30 seconds after establishing direct connection |
Mar-03 18:14:04 | JowiHue | socket opened for Phoscon-GW on 192.168.0.114:443 |
Mar-03 18:14:01 | JowiHue | ============================================================ ================================== |
Mar-03 18:14:01 | JowiHue | 0 Animations available for use in this plugin |
Mar-03 18:14:01 | JowiHue | 0 Local scenes available for use in the JowiHue plugin |
Mar-03 18:14:01 | JowiHue | 22 Presets available for use in the JowiHue plugin |
Mar-03 18:14:01 | JowiHue | -------------------------------------Plugin info --------------------------------------------- |
Mar-03 18:14:01 | JowiHue | 4 Alarm sensor(s) found on bridge 'Phoscon-GW' with 4 supporting HS device(s) |
Mar-03 18:14:01 | JowiHue | 1 Humidity sensor(s) found on bridge 'Phoscon-GW' with 1 supporting HS device(s) |
Mar-03 18:14:01 | JowiHue | 1 Daylight sensor found on bridge 'Phoscon-GW' |
Mar-03 18:14:01 | JowiHue | 6 Lightlevel sensor(s) found on bridge 'Phoscon-GW' with 6 supporting HS device(s) |
Mar-03 18:14:01 | JowiHue | 1 Temperature sensor(s) found on bridge 'Phoscon-GW' with 1 supporting HS device(s) |
Mar-03 18:14:01 | JowiHue | 17 Motion sensor(s) found on bridge 'Phoscon-GW' with 6 supporting HS device(s) |
Mar-03 18:14:01 | JowiHue | 1 Remote switch(s) found on bridge 'Phoscon-GW' with 1 supporting HS device(s) |
Mar-03 18:14:01 | JowiHue | Bridge Phoscon-GW is at version 2.5.59 of type deCONZ on a ConBee |
Mar-03 18:14:01 | JowiHue | 5 Groups available on bridge 'Phoscon-GW' |
Mar-03 18:14:01 | JowiHue | 7 lights and/or plugs connected to bridge 'Phoscon-GW' |
Mar-03 18:14:01 | JowiHue | -------------------------------------Bridge info --------------------------------------------- |
