Number of decimals resetting
  • Number of decimals resetting
    For my Xiaomi temperature/humid sensors, I’ve changed the number of decimals to show from 2 to 1 in “status graphics”. But after a restart of JH/HomeSeer, the settings are reverted back to 2 decimals again. Is this expected behavior? How can I avoid this?
    Yes, this is expected behavior as with each restart the plugin has to check if the setting Celcius or Farenheit has changed. This causes the decimals to be reset with the start. Will check if I could change that behaviour....
    -- Wim
      For me, a setting in the plugin config like “Number of decimals for temperature sensors” would be enough.
        I have just submitted release 2.0.3.2 to HST, which has now the ability to set the number of decimals for temperature and Humidity values. Remember to use rebuild device values for sensors after setting, so it will also change exisiting devices!
        Wim
        -- Wim
