log error
  • log error
    Hi wim,
    i got theses on startup of hs3.
    Mar-25 15:01:19 Info Plugin SqueezeBox with instance Player_b827ebad944c has connected. IP:127.0.0.1:58040
    Mar-25 15:01:16 JowiHue Extra info: change_device-0-8199-3
    Mar-25 15:01:16 JowiHue Error: (HSEvent)::Error running config change:Min (49) must be less than or equal to max (-1) in a Range object.
    Mar-25 15:01:16 JowiHue Extra info: change_device-0-8196-3
    Mar-25 15:01:16 JowiHue Error: (HSEvent)::Error running config change:Min (46) must be less than or equal to max (-1) in a Range object.
    Mar-25 15:01:16 JowiHue Extra info: change_device-0-8149-3
    Mar-25 15:01:16 JowiHue Error: (HSEvent)::Error running config change:Min (36) must be less than or equal to max (-1) in a Range object.
    Mar-25 15:01:16 JowiHue Extra info: change_device-0-8148-3
    Mar-25 15:01:16 JowiHue Error: (HSEvent)::Error running config change:Min (35) must be less than or equal to max (-1) in a Range object.
    Mar-25 15:01:15 JowiHue Extra info: change_device-0-6138-3
    Mar-25 15:01:15 JowiHue Error: (HSEvent)::Error running config change:Min (21) must be less than or equal to max (-1) in a Range object.
    Mar-25 15:01:15 JowiHue Extra info: change_device-0-4929-3
    Mar-25 15:01:15 JowiHue Error: (HSEvent)::Error running config change:Min (14) must be less than or equal to max (-1) in a Range object.
    Mar-25 15:01:15 JowiHue Extra info: change_device-0-4928-3
    Mar-25 15:01:15 JowiHue Error: (HSEvent)::Error running config change:Min (13) must be less than or equal to max (-1) in a Range object.
    Mar-25 15:01:15 JowiHue Extra info: change_device-0-4904-3
    Mar-25 15:01:15 JowiHue Error: (HSEvent)::Error running config change:Min (5) must be less than or equal to max (-1) in a Range object.
    Matthieu,
    I see these also on a rare occasion, but have not found why this error occurs. I am guessing that HS3 is somehow already calling th plugin even though it it not fuly started yet. It seems some range is not initialised during the time of the call. Most often a subsequent start of the plugin won't throw these errors.
    Also, once started the error does not seem to cause other issues.... I will keep an eye on it, maybe I will be lucky someday catching it
    -- Wim
      yes this is what i thought too ! thanks wim.
        I will delay some startup event action
