The darn server rebooted this morning and now the interface isnt working. Everything else seems to be ok. I can control the Hue lights with the Hue app ok.
Also it always starts off with the wrong IP and I have no idea how to change that. Seems to get itself figured out eventually
Apr-05 11:03:10 | JowiHue | Debug: (Bridgescan) Start:End search for bridges |
Apr-05 11:03:10 | JowiHue | Error: (BridgeFound):Start:Object reference not set to an instance of an object. |
Apr-05 11:03:10 | JowiHue | Warning: Bridge Philips hue changed IP from 10.215.81.139:80 to 10.215.81.106:80 - Restarting processes for this bridge |
Apr-05 11:03:02 | JowiHue | Debug: (SetDeviceByUserRequest) Start::End |
Apr-05 11:03:02 | JowiHue | Error: (SetDeviceByUserRequest):Start:SDBUR setstate on start -----Object variable or With block variable not set. |
Apr-05 11:03:02 | JowiHue | Debug: (SetDeviceByUserRequest) Start:SetDeviceByUserRequest:Start ref=502 Action:255 controltype:5 Controlstring: |
Apr-05 11:02:41 | JowiHue | Debug: (InitPlugin) Start:Config Done InitOK=True |
Apr-05 11:02:41 | JowiHue | ============================================================ ================================== |
Apr-05 11:02:41 | JowiHue | Device of reporting bridge and light firmware updates is enabled |
Apr-05 11:02:41 | JowiHue | 2 Animations available for use in this plugin |
Apr-05 11:02:41 | JowiHue | 8 Local scenes available for use in the JowiHue plugin |
Apr-05 11:02:41 | JowiHue | 22 Presets available for use in the JowiHue plugin |
Apr-05 11:02:41 | JowiHue | -------------------------------------Plugin info --------------------------------------------- |
Apr-05 11:02:41 | JowiHue | Bridge Philips hue is at version of type on a |
Apr-05 11:02:41 | JowiHue | 7 Groups available on bridge 'Philips hue' |
Apr-05 11:02:41 | JowiHue | 16 lights and/or plugs connected to bridge 'Philips hue' |
Apr-05 11:02:41 | JowiHue | -------------------------------------Bridge info --------------------------------------------- |
Apr-05 11:02:41 | JowiHue | Debug: (InitPlugin) Start:Refreshing Bridge Philips hue |
Apr-05 11:02:41 | JowiHue | Debug: (InitPlugin) Start:Starting Device checks |
Apr-05 11:02:41 | JowiHue | Debug: (InitDevices) :InitDevices: End Hue Device search |
Apr-05 11:02:39 | JowiHue | Debug: (Bridgescan) :Start Scan for bridges 4/5/2019 11:02:39 |
Apr-05 11:02:39 | JowiHue | Debug: (InitDevices) :InitDevices: Searching for devices |
Apr-05 11:02:38 | JowiHue | * Bridge Philips hue at 10.215.81.139:80 not connected (not reachable) |
Apr-05 11:02:38 | JowiHue | Warning: Bridge Philips hue not reachable on 10.215.81.139 is bridge powered on or IP/Port address has changed? |
Apr-05 11:02:38 | JowiHue | Cannot find bridge Philips hue on ip adress 10.215.81.139:80 marking unreachable |
Apr-05 11:02:38 | JowiHue | Debug: (BridgeCheckIP) :IP address 10.215.81.139 not responding: Unable to connect to the remote server |
Apr-05 11:02:35 | JowiHue | Warning: JowiHue Plugin is not yet in ready state. Command not executed, please resend after initialisation finished |
Apr-05 11:02:35 | JowiHue | Debug: (SetDeviceByUserRequest) :SetDeviceByUserRequest:Start ref=502 Action:255 controltype:5 Controlstring: |
Apr-05 11:02:16 | JowiHue | Debug: (FindBridgesSelf) :Searching for Hue devices |
Apr-05 11:02:16 | JowiHue | Debug: (InitPlugin) :InitPlugin: initial checks |
Apr-05 11:02:16 | JowiHue | InitIO:Plugin basic initialisation done |
Apr-05 11:02:16 | JowiHue | Debug: (MainWatchTimer) :Checking plugin health 4/5/2019 11:02:16 |
Apr-05 11:02:16 | JowiHue | Debug: (GetAnimations) :GetAnimations finished normal |
Apr-05 11:02:16 | JowiHue | Debug: (InitScenes) :GetScenes finished normally |
Apr-05 11:02:15 | JowiHue | Debug: (InitIO) ![]() |
Apr-05 11:02:15 | JowiHue | Starting plugin JowiHue 2.0.3.1 on Windows |
