Need Help Getting Started with ConBee
    #16
    is there some king of step by step manual that would explain how to get started with deCONZ/ ConBee? I am trying to add Keen Vents to my HS3 but nothing really works :/ all i got to work is the main screen of deCONZ that does not tells me much ... how do i add new devices? why are my vents not adding to phoscon app?
    on top of that about every minute or two i am getting HS3 JowieHue plugin crash message. i am attaching few screenshots for reference. maybe someone will get an idea what is happening here ...
    also, on the conbee box there is sticker with install code ... do i need to enter that somewhere to get it to work? can't find anything for that in product manual.
    i am using conbee II and windows server 2012.
Name:	main screen.jpg
ID:	1310593Click image for larger version
Name:	main screen nod.jpg
ID:	1310594Click image for larger version
Name:	jowihue crash.jpg
ID:	1310595Click image for larger version
ID:	1310596Click image for larger version
Name:	bridge maintenance.jpg
      #17
      It appears that your ConBee is installed and connecting just fine. You now need to add the vents as lights. Start a scan from phoscan or jowihue and then pull the battery on a vent and reinsert. ConBee should find it in a few minutes.
      tenholde
        #18
        i am trying to add vents (lights) like this: battery in, i get double blinking green light on the vent, the bar in phoscon app goes from left to right ... nothing is found do i need to configure the light somehow in ConBee before i start adding it?
          #19
          Make sure the ConBee is closer enough to the vent
          tenholde
            #20
            Also, you may need to reset the vent if you had it paired to the Keen hub
            tenholde
              #21
              FINALLY was able to get it to work ! as per respond #9 i tried controller on another machine, windows 10 desktop and it start working. i am able to control it from HS3 except for one button: ON. in manager is shows Vent ON but vent did not move so to get it to 100% i need to either slide it all the way or click on "UP" few times. I am attaching some screenshots and log below. Thanks!
              Date/Time Pri Type/Error Message/Source
              Jun-15 01:53:11 Device Control Device: Vents JowiHue Vent 2 to On (255) by/from: CAPI Control Handler
              Jun-15 01:50:13 Device Control Device: Vents JowiHue Vent 2 to (value)% (52) by/from: CAPI Control Handler
              Jun-15 01:49:46 Device Control Device: Vents JowiHue Vent 1 to (value)% (82) by/from: CAPI Control Handler
              Jun-15 01:49:25 Device Control Device: Vents JowiHue Vent 2 to (value)% (87) by/from: CAPI Control Handler
              Jun-15 01:49:16 Device Control Device: Vents JowiHue Vent 1 to Off (0) by/from: CAPI Control Handler
              Jun-15 01:49:15 Device Control Device: Vents JowiHue Vent 2 to Off (0) by/from: CAPI Control Handler
              Jun-15 01:48:52 Device Control Device: Vents JowiHue Vent 1 to On (255) by/from: CAPI Control Handler
              Jun-15 01:48:49 Device Control Device: Vents JowiHue Vent 2 to On (255) by/from: CAPI Control Handler
              Jun-15 01:46:41 Device Control Device: Vents JowiHue Vent 2 to On (255) by/from: CAPI Control Handler
              Jun-15 01:46:35 Device Control Device: Vents JowiHue Vent 1 to On (255) by/from: CAPI Control Handler
              Jun-15 01:46:33 Device Control Device: Vents JowiHue Vent 1 to Off (0) by/from: CAPI Control Handler
              Jun-15 01:46:31 Device Control Device: Vents JowiHue Vent 2 to Off (0) by/from: CAPI Control Handler
              Jun-15 01:45:40 Device Control Device: Vents JowiHue Vent 2 to (value)% (100) by/from: CAPI Control Handler
              Jun-15 01:45:38 Device Control Device: Vents JowiHue Vent 1 to (value)% (100) by/from: CAPI Control Handler
              Jun-15 01:45:34 Device Control Device: Vents JowiHue Vent 2 to On (255) by/from: CAPI Control Handler
              Jun-15 01:45:31 Device Control Device: Vents JowiHue Vent 2 to On (255) by/from: CAPI Control Handler
              Jun-15 01:45:24 Device Control Device: Vents JowiHue Vent 1 to On (255) by/from: CAPI Control Handler
              Jun-15 01:45:19 Device Control Device: Vents JowiHue Vent 1 to Off (0) by/from: CAPI Control Handler
              Jun-15 01:45:15 Device Control Device: Vents JowiHue Vent 2 to Off (0) by/from: CAPI Control Handler
              Jun-15 01:45:08 Device Control Device: Vents JowiHue Vent 2 to (value)% (1) by/from: CAPI Control Handler
              Jun-15 01:45:04 Device Control Device: Vents JowiHue Vent 2 to (value)% (94) by/from: CAPI Control Handler
              Jun-15 01:44:59 Device Control Device: Vents JowiHue Vent 1 to (value)% (93) by/from: CAPI Control Handler
              Jun-15 01:44:56 Device Control Device: Vents JowiHue Vent 1 to (value)% (1) by/from: CAPI Control Handler
              Jun-15 01:44:53 Device Control Device: Vents JowiHue Vent 1 to (value)% (51) by/from: CAPI Control Handler
              Jun-15 01:44:43 Device Control Device: Vents JowiHue Vent 1 to (value)% (94) by/from: CAPI Control Handler
              Jun-15 01:44:40 Device Control Device: Vents JowiHue Vent 2 to On (255) by/from: CAPI Control Handler
              Jun-15 01:44:36 Device Control Device: Vents JowiHue Vent 2 to On (255) by/from: CAPI Control Handler
              Jun-15 01:44:30 Device Control Device: Vents JowiHue Vent 2 to Off (0) by/from: CAPI Control Handler
              Jun-15 01:44:28 Device Control Device: Vents JowiHue Vent 1 to Off (0) by/from: CAPI Control Handler
              Jun-15 01:44:10 Device Control Device: Vents JowiHue Vent 1 to On (255) by/from: CAPI Control Handler
              Jun-15 01:44:05 Device Control Device: Vents JowiHue Vent 2 to On (255) by/from: CAPI Control Handler
              Jun-15 01:44:01 Device Control Device: Vents JowiHue Vent 2 to Up (256) by/from: CAPI Control Handler
              Jun-15 01:42:05 Device Control Device: Vents JowiHue Vent 1 to Up (256) by/from: CAPI Control Handler
              Jun-15 01:42:04 Device Control Device: Vents JowiHue Vent 1 to Up (256) by/from: CAPI Control Handler
              Jun-15 01:42:02 Device Control Device: Vents JowiHue Vent 1 to Up (256) by/from: CAPI Control Handler
              Jun-15 01:41:59 Device Control Device: Vents JowiHue Vent 2 to Up (256) by/from: CAPI Control Handler
              Jun-15 01:41:57 Device Control Device: Vents JowiHue Vent 2 to Up (256) by/from: CAPI Control Handler
              Jun-15 01:41:53 Device Control Device: Vents JowiHue Vent 2 to Up (256) by/from: CAPI Control Handler
              Jun-15 01:41:44 Device Control Device: Vents JowiHue Vent 2 to Up (256) by/from: CAPI Control Handler
              Jun-15 01:41:39 Device Control Device: Vents JowiHue Vent 2 to Up (256) by/from: CAPI Control Handler
              Jun-15 01:41:37 Device Control Device: Vents JowiHue Vent 1 to Up (256) by/from: CAPI Control Handler
              Jun-15 01:41:00 Device Control Device: Vents JowiHue Vent 2 to On (255) by/from: CAPI Control Handler
              Jun-15 01:40:16 Device Control Device: Vents JowiHue Vent 1 to Off (0) by/from: CAPI Control Handler
              Jun-15 01:40:10 Warning File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\images\JowiHue\ZZL_Light_off.png
              Jun-15 01:40:10 Warning File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\images\JowiHue\ZZL_Light_unreachable.png
              Jun-15 01:37:40 Device Control Device: Vents JowiHue Vent1 to Up (256) by/from: CAPI Control Handler
              Jun-15 01:37:37 Device Control Device: Vents JowiHue Vent1 to Off (0) by/from: CAPI Control Handler
              Jun-15 01:37:32 Device Control Device: Vents JowiHue Vent1 to Up (256) by/from: CAPI Control Handler
              Jun-15 01:36:45 Device Control Device: Vents JowiHue Vent1 to On (255) by/from: CAPI Control Handler
              Jun-15 01:36:41 Device Control Device: Vents JowiHue Vent1 to On (255) by/from: CAPI Control Handler
              Jun-15 01:35:25 JowiHue 3 Local scenes available for use in the JowiHue plugin
              Jun-15 01:35:25 JowiHue 22 Presets available for use in the JowiHue plugin
              Jun-15 01:35:19 Plug-In Finished initializing plug-in JowiHue
              Jun-15 01:35:19 Starting Plug-In JowiHue loaded in 612 milliseconds
              Jun-15 01:35:19 Starting Plug-In Plugin JowiHue started successfully in 298 milliseconds
              Jun-15 01:35:19 JowiHue Starting plugin JowiHue 2.0.3.3 on Windows
              Jun-15 01:35:19 Starting Plug-In Initializing plugin JowiHue ...
              Jun-15 01:35:18 Info Plugin JowiHue has connected. IP:127.0.0.1:51716
              Jun-15 01:34:57 Plug-In Found plug-in: JowiHue, version: 2.0.3.3
Name:	deCONZ new host.jpg
ID:	1310622Click image for larger version
Name:	another host computer.jpg
ID:	1310623Click image for larger version
Name:	bridge maintenance1.jpg
                #22
                In HS, to close vent, I set it to OFF. To open vent, I set it to 254. Never could get ON to work.
                tenholde
                  #23
                  Great! Thanks for all your help!
                  BTW, how do you get JowiHue plugin to read all VENT data (Temperature, Pressure, Battery)? you have mentioned that in post "Keen Vents Battery Reading Incorrect" reply #4 ... Do i need to change anything on HS end to show that? Here is what i got.
                    #24
                    Are the vents working in JowiHue now? I want to get a few but definitely need to have all attributes and full control via in Homeseer. Thx!
