hi,
today I installed a new system and did a restore from a backup. But it seems Jowihue does not really like this. It find and creates all my lights on the connected bridge, but for some reason it does not recreate the sensors. I even uninstalled the plugin, deleted everything jowihue from the homeseer folder and re-installed it. When looking at bridge maintenance, it says:
But when I then click on the drop down it shows none. In HS all the lights are created and working, but none sensors show. Below some errors that show in the log:
Sensors on Bridge (holding 12 sensors)
Apr-19 14:10:31 | JowiHue | Error: (BuildSliderSensors)::web Maintenance:Object reference not set to an instance of an object. |
Apr-19 14:10:30 | JowiHue | Error: (BuildSliderSensors)::web Maintenance:Object reference not set to an instance of an object. |
Apr-19 14:06:52 | JowiHue | Error: (BuildSliderSensors)::web Maintenance:Object reference not set to an instance of an object. |
Apr-19 14:06:47 | JowiHue | Refresh bridge r2donker set to 30 seconds after establishing direct connection |
Apr-19 14:06:46 | JowiHue | socket opened for r2donker on 192.168.1.149:443 |
Apr-19 14:06:44 | JowiHue | ============================================================ ================================== |
Apr-19 14:06:44 | JowiHue | 0 Animations available for use in this plugin |
Apr-19 14:06:44 | JowiHue | 0 Local scenes available for use in the JowiHue plugin |
Apr-19 14:06:44 | JowiHue | 22 Presets available for use in the JowiHue plugin |
Apr-19 14:06:44 | JowiHue | -------------------------------------Plugin info --------------------------------------------- |
Apr-19 14:06:44 | JowiHue | Bridge r2donker is at version 2.5.20 of type deCONZ on a ConBee |
Apr-19 14:06:44 | JowiHue | 11 Groups available on bridge 'r2donker' |
Apr-19 14:06:44 | JowiHue | 12 lights and/or plugs connected to bridge 'r2donker' |
Apr-19 14:06:44 | JowiHue | -------------------------------------Bridge info --------------------------------------------- |
Apr-19 14:06:43 | JowiHue | Error: (AddOrUpdatebridgeuser)::SQL logic error or missing database no such column: False |
Apr-19 14:06:43 | JowiHue | * Connected to bridge r2donker at 192.168.1.149:80 |
Apr-19 14:06:42 | Plug-In | Finished initializing plug-in JowiHue |
Apr-19 14:06:42 | Starting Plug-In | JowiHue loaded in 503 milliseconds |
Apr-19 14:06:42 | Starting Plug-In | Plugin JowiHue started successfully in 193 milliseconds |
Apr-19 14:06:42 | JowiHue | InitIO:Plugin basic initialisation done |
Apr-19 14:06:42 | JowiHue | Error: (InitDatabase)::Object reference not set to an instance of an object. |
Apr-19 14:06:42 | JowiHue | Error: (InitDatabase)::Error occured at table SensorTypes with statement PRAGMA table_info(SensorTypes) |
Apr-19 14:06:42 | JowiHue | Table SensorType has been altered |
Apr-19 14:06:42 | JowiHue | Starting plugin JowiHue 2.0.3.2 on Windows |
Apr-19 14:06:42 | Starting Plug-In | Initializing plugin JowiHue ... |
Apr-19 14:06:42 | Info | Plugin JowiHue has connected. IP:127.0.0.1:57273 |
Apr-19 14:06:34 | Info | Plugin JowiHue with instance: has disconnected |
Apr-19 14:06:34 | JowiHue | JowiHue Plugin is stopped. Thanks for using it :-) |
Apr-19 14:06:34 | JowiHue | disconnecting bridge r2donker |
Apr-19 14:06:34 | Plug-In | Shutting down Plug-In: JowiHue |
Apr-19 14:06:21 | JowiHue | Error: (BuildSliderSensors)::web Maintenance:Object reference not set to an instance of an object. |
Apr-19 14:06:09 | JowiHue | Error: (BuildSliderSensors)::web Maintenance:Object reference not set to an instance of an object. |
Apr-19 14:06:06 | JowiHue | Error: (BuildSliderSensors)::web Maintenance:Object reference not set to an instance of an object. |
Apr-19 14:05:25 | JowiHue | Scanning New sensors started. If New lights are found the plugin will add them automatically |
Apr-19 14:04:10 | JowiHue | Error: (BuildSliderSensors)::web Maintenance:Object reference not set to an instance of an object. |
Apr-19 14:04:03 | JowiHue | Error: (BuildSliderSensors)::web Maintenance:Object reference not set to an instance of an object. |
Apr-19 14:03:50 | JowiHue | Refresh bridge r2donker set to 30 seconds after establishing direct connection |
Apr-19 14:03:49 | JowiHue | socket opened for r2donker on 192.168.1.149:443 |
Apr-19 14:03:49 | JowiHue | Devices added for new group All Lights |
Apr-19 14:03:49 | JowiHue | Devices added for new light Gazebo light left |
Apr-19 14:03:49 | JowiHue | Devices added for new light Computer room light |
Apr-19 14:03:49 | JowiHue | Devices added for new light Stairs |
Apr-19 14:03:49 | JowiHue | Devices added for new light Porch light |
Apr-19 14:03:49 | JowiHue | Devices added for new light Landing light 2 |
Apr-19 14:03:49 | JowiHue | Devices added for new light Landing light 1 |
Apr-19 14:03:49 | JowiHue | Devices added for new light Hall light |
Apr-19 14:03:49 | JowiHue | Devices added for new light Kitchen Leds |
Apr-19 14:03:49 | JowiHue | Devices added for new light Garden lamppost 1 |
Apr-19 14:03:49 | JowiHue | Devices added for new light Gazebo light right |
Apr-19 14:03:48 | JowiHue | Devices added for new light Kitchen mood light 1 |
Apr-19 14:03:48 | JowiHue | Devices added for new light Utility light |
Apr-19 14:03:46 | JowiHue | Error: (AddOrUpdatebridgeuser)::SQL logic error or missing database no such column: False |
Apr-19 14:03:46 | JowiHue | Registration of bridge was succesfull |
