Cant read sensors, lights or switches from DeConz.
  • Cant read sensors, lights or switches from DeConz.
    Log details after restart:-
    Apr-27 4:03:24 PM JowiHue Error: (BuildBridgeTab)::web Maintenance:Object reference not set to an instance of an object.
    Apr-27 4:03:10 PM JowiHue Error: (BuildBridgeTab)::web Maintenance:Object reference not set to an instance of an object.
    Apr-27 4:02:27 PM JowiHue Pressed button for immediate scan for bridges - scanning started
    Apr-27 4:02:07 PM JowiHue recreating bridge device CompSue18X
    Apr-27 4:01:46 PM JowiHue ============================================================ ==================================
    Apr-27 4:01:46 PM JowiHue 0 Animations available for use in this plugin
    Apr-27 4:01:46 PM JowiHue 0 Local scenes available for use in the JowiHue plugin
    Apr-27 4:01:46 PM JowiHue 22 Presets available for use in the JowiHue plugin
    Apr-27 4:01:46 PM JowiHue -------------------------------------Plugin info ---------------------------------------------
    Apr-27 4:01:46 PM JowiHue 4 Generic status sensor found on bridge 'Philips hue'
    Apr-27 4:01:46 PM JowiHue 1 Daylight sensor found on bridge 'Philips hue'
    Apr-27 4:01:46 PM JowiHue 4 Remote switch(s) found on bridge 'Philips hue' with 4 supporting HS device(s)
    Apr-27 4:01:46 PM JowiHue Bridge Philips hue is at version 1931069120 of type BSB002
    Apr-27 4:01:46 PM JowiHue 12 Groups available on bridge 'Philips hue'
    Apr-27 4:01:46 PM JowiHue 30 lights and/or plugs connected to bridge 'Philips hue'
    Apr-27 4:01:46 PM JowiHue -------------------------------------Bridge info ---------------------------------------------
    Apr-27 4:01:35 PM JowiHue Error: (FindBridgesSelf)::Object reference not set to an instance of an object.
    Apr-27 4:01:33 PM Plug-In Finished initializing plug-in JowiHue
    Apr-27 4:01:33 PM Starting Plug-In JowiHue loaded in 2916 milliseconds
    Apr-27 4:01:33 PM Starting Plug-In Plugin JowiHue started successfully in 1381 milliseconds
    Vendor dresden elektronik
    Product RaspBee
    Version 2.05.64 / 22/04/2019
    Firmware 26330500
    JowiHue 2.0.3.2
    Bridge maintenance :- DeConz blank – Philips hue fully populated
    Have removed and re authenticated the bridge. Disabled - Re enabled and still no joy.
    15 Xiaomi aquara multi sensors, 2 Ikea mains switches. 1 Hue bulb and 1 Philips hue bulb and meshed and connected and working on the DeConz.
    Have tried everything I can think of and suggested by the forum but have run out of ideas. HELP!
    In the log I see only a Philips Hue bridge enabled?
    does the error
    occur at every restart of the plugin, even after the re-authentication? If it does, could you send me the detailed log of the plugin, including the startup? To do this follow these steps:
    1. Go to the configuration page of the plugin , the logging tab. Enable detailed loggin and log to file.
    2. Stop and restart the plugin an let it run for 10 minutes or so
    3. Go to the configuration page and disable detailed logging and trace to file
    4. In the \logs directory of the Homeseer installation directory you will fid the JowiHue.log file, send this one to me?
    5. Please also include the JowiHue database, you can find it in \Data\JowiHue\JowiHue.db
    Send the file to w dot vuyk at upcmail dot nl?
    Wim
    -- Wim
      Hi Wim,
      Unfortunately the same error has reoccurred. This time after a power outage/ windows 10 update then an HS3 update. I have emailed you the file logs again.
      Can you please help? It appears the windows database cannot recover properly in the event of an unexpected powercut? Is it worth a UPS? what are your views?
      Kind regards
      Cjogo
        cjogo,
        The solution is to check the databases of Homeseer and the plugin. you find it in the data directory and the data\JowiHue directory. Both have a regular copy when Homeser and/or Jowi have been restarted. Check for the version that are made before the power failure. Stop Homeseer and make the correct backup versions the current ones. Then start HomeSeer. This should resolve the problem?
        Wim
        -- Wim
