Contacting HomeSeer This Week
See more
See less
Hue Bridge Registration Error
  • Hue Bridge Registration Error
    Running HS3 3.0.0.531 on Hometroller S6 Win 7 with JowiHue 2.0.3.2. Hue Lights. Homeseer can control all Hue lights via Hue Bridge, but getting log errors and error in HS3 startup.
    Have tried reboots and disable plugin- no change. Also deleted JowiHue user in meethue and tried repairing with hub (several times0
    Light state is usually shown as unreachable.
    Bridge registers, and lets me scan for lights but I get the following errors in log:-
    Apr-30 19:47:00 JowiHue Warning: Bridge registered, device already present - updating device
    Apr-30 19:46:59 JowiHue Error: (AddOrUpdatebridgeuser)::SQL logic error or missing database no such column: False
    Apr-30 19:46:59 JowiHue Registration of bridge was succesfull
    Then on a lighting action:-
    Apr-30 20:23:56 JowiHue Info: -- Unregistered bridge found on network at 192.168.178.235
    Apr-30 20:23:01 JowiHue Warning: SetLightSuspected: Bridge has been reset, setting all bridge lights suspected, so original settings can be restored later if needed
    Apr-30 20:23:01 Device Control Device: System System Nighttime Custom to On (100)
    Apr-30 20:23:01 Device Control Device: Garage Eaves Front Dimmer Switch Multilevel 1 to 10% (10)
    Apr-30 20:23:01 Device Control Device: JowiHue JowiHue LR Table to 150 (150)
    The unregistered bridge message repeats every 10 minutes. In bridge maintenance I have "Bridge on IP address: 192.168.178.235" (correct, static reservation)
    Log of plugin startup (the sensors/ switches shown haven't been removed) :-
    Apr-30 20:49:18 JowiHue Debug: (Bridgescan) :End search for bridges
    Apr-30 20:48:59 JowiHue Info: -- Unregistered bridge found on network at 192.168.178.235
    Apr-30 20:48:59 JowiHue Warning: Or remove the devices belonging to this sensor
    Apr-30 20:48:59 JowiHue Warning: Did you remove a sensor from the bridge but left the HomeSeer devices? Re-add the sensor to the bridge and your events are save
    Apr-30 20:48:59 JowiHue Warning: Orphaned Sensor Study Switch (523) found, not found on any connected bridge
    Apr-30 20:48:59 JowiHue Warning: Orphaned Sensor LR Tap (522) found, not found on any connected bridge
    Apr-30 20:48:59 JowiHue Warning: Orphaned Sensor Bedroom GiGi Switch (520) found, not found on any connected bridge
    Apr-30 20:48:59 JowiHue Warning: Orphaned Sensor Bedside Chris Switch (518) found, not found on any connected bridge
    Apr-30 20:48:59 JowiHue Debug: (InitPlugin) :Config Done InitOK=True
    Apr-30 20:48:59 JowiHue InitPlugin:No registered bridge found; please register a bridge through the configuration page
    Apr-30 20:48:59 JowiHue Debug: (InitPlugin) :Starting Device checks
    Apr-30 20:48:49 JowiHue Warning: SetLightSuspected: Bridge has been reset, setting all bridge lights suspected, so original settings can be restored later if needed
    Apr-30 20:48:48 JowiHue Error: (AddOrUpdatebridgeuser)::SQL logic error or missing database no such column: False
    Apr-30 20:48:48 JowiHue Debug: (InitDevices) :InitDevices: End Hue Device search
    Apr-30 20:48:47 JowiHue Debug: (Bridgescan) :Start Scan for bridges 30/04/2019 20:48:47
    Apr-30 20:48:47 JowiHue Debug: (InitDevices) :InitDevices: Searching for devices
    Apr-30 20:48:46 JowiHue * Connected to bridge Hue Jackson at 192.168.178.235:80
    Apr-30 20:48:46 JowiHue Debug: (FindBridgesSelf) :Searching for Hue devices
    Apr-30 20:48:45 Plug-In Finished initializing plug-in JowiHue
    Apr-30 20:48:45 Starting Plug-In JowiHue loaded in 992 milliseconds
    Apr-30 20:48:45 JowiHue Debug: (InitPlugin) :InitPlugin: initial checks
    Apr-30 20:48:45 JowiHue Debug: (MainWatchTimer) :Checking plugin health 30/04/2019 20:48:45
    Apr-30 20:48:45 Starting Plug-In Plugin JowiHue started successfully in 603 milliseconds
    Apr-30 20:48:45 JowiHue InitIO:Plugin basic initialisation done
    Apr-30 20:48:45 JowiHue Debug: (GetAnimations) :GetAnimations finished normal
    Apr-30 20:48:45 JowiHue Debug: (InitScenes) :GetScenes finished normally
    Apr-30 20:48:45 JowiHue Debug: (InitIO) atabase location Data Source=C:\Program Files\HomeSeer HS3/Data/JowiHue/JowiHue.db;ReadUncommitted=True;Version=3;Pooling=True;Max Pool Size=100;
    Apr-30 20:48:45 JowiHue Starting plugin JowiHue 2.0.3.2 on Windows
    Apr-30 20:48:44 Starting Plug-In Initializing plugin JowiHue ...
    Any suggestions?
    Could you send me a detailed log on this by following these steps?
    1. go the configuration page of the plugin, the tracing tab and set detailed tracing and tracing to log to enabled.
    2. Stop the plugin and restart it
    3. Let the plugin run for 15 minutes and then try to perform actions on lights an such.
    4. Try to register the bridge again
    5. go to the configuration page and disable the detailed logging and log to file options.
    6. In the \Logs directory of the HS installation you will find a file called JowiHue.log. Could you send me this file?
    Send the file to w dot vuyk at upcmail dot nl?
    Also include the file \Data\JowiHue\JowiHue.db?
    Wim
    -- Wim
      Thanks! will send tomorrow...
