Xiaomi Water Sensor not Reliable
  • Xiaomi Water Sensor not Reliable
    I have had this sensor for several months. I have the sensor on the floor behind my toilet. This morning my toilet somewhat flooded the bathroom. Nothing from the sensor. When I checked HS3 Device page it shows the last detected water was March 7 and Battery update was yesterday at 91%. At this point if it's something importand I'm not going to use Zigbee. For now I'll just use it for my temp sensors.
    Jim
    I just tested the sensor by getting my finger wet and putting them accross the contacts. It detected water on the 4th try but now it looks to be stuck on Flood Alert even though it's now dry. I tested the sensor the same when I first got them and the sensors did not behave this way. Before soon as I put on my wet finger the first time it would show flood alert then soon as i dried them the flood alert went away.
    Jim
      Jim,
      I did not check the flood sensor for a long time (last change was Januari here). Checked it here bu throwing it in the sink with water runing, but it responded immediatley. Don't know what happend in your installaion.
      Maybe rescan the device by resetting it while the device scan is open?
      Wim
      -- Wim
        I too randomly tested one of my sensors that I installed in January and it immediately detected water and notified me.
          were there enough router near the xiaomi sensor?
          jbfoster
            In this particular case the router was one floor below the sensor.
              Jim
              I have 8 of these, which I test periodically. Testing today showed all detecting water. One stayed in alarm setting after drying. That one I had to rescan in Phoscon. My deConz dongle is on the first floor. Three sensors are on the second floor and not directly above the dongle. Since a water leak can be disastrous, in particularly critical areas, I have both the zigbee sensor and a Z-wave sensor. Elliott
                I've been away so I havn't been able to respond. I have two Xiaomi routers within 8 and 12 feet so signal is not a problem. I have done nothing with the sensor yet. I have not messed with it since May 18th. I just tested it several times.
                1st - Went into Flood Alert but took several minutes to back to Dry.
                2nd - Went into Flood Alert and took about 10 seconds to return to Dry.
                3rd - No response.
                4th - Went to Flood then Dry just fine.
                5th - Went to Flood then Dry just fine.
                6th - Went to Flood then Dry just fine.
                I waited about 1 minute in between tests starting with the 2nd test and after. Maybe it just has a hiccup every now and then and doesn't respond.
                Jim
