Xiaomi Smart Plug miss sensor device (ZHAConsumption)?
  • Xiaomi Smart Plug miss sensor device (ZHAConsumption)?
    Hi Wim,
    I have one Xiaomi smart plug (modelid: "lumi.plug.mitw01", swversion: "01-10-2018")
    The plugin creates three devices (lumi.plug; ZHAPower)
    Have some problem
    1. loss one device (ZHAConsumption)
    2. ZHAPower device no value : (
    detail information: (I use: ConebeeII)
    ZHAPower
    **************************** Object info *****************************
    "state": {
    "lastupdated": "2019-06-06T02:41:11",
    "power": -1
    "config": {
    "on": true,
    "reachable": true
    "name": "Power 3",
    "type": "ZHAPower",
    "modelid": "lumi.plug.mitw01",
    "manufacturername": "LUMI",
    "swversion": "01-10-2018",
    "uniqueid": "00:15:8d:00:02:8b:3d:0c-01-0b04",
    "ep": 1,
    "etag": "bf511a13f8b44cb357694252ad67edd1"
    ************************* End Object info ***************************
    It seems the deCONZ is not getting all values to the REST API. Often it can help to do a rescan of the device by initiating a scan for devices on the configuration page of the plugin and then resetting the plug. deCONZ should then do a rescan of all possibilities of the device, hopefully refreshing the information?
    Wim
    -- Wim
      Hi Wim,
      I re-scan of the device and resetting the plug but still miss sensor device (ZHAConsumption) ><
        I have rechecked on the github here and I think there is no support yet for this specific model. I have found support for several models, like "lumi.relay.c2acn01" and "lumi.ctrl_ln1.aq1" or "lumi.ctrl_neutral2". But so far I cannot find info on "lumi.plug.mitw01"
        So I am afraid you will need to ask for support on github here. To help setup your request, pleas check this page for the needed info: https://github.com/dresden-elektroni...Device-Support:
        Wim
        -- Wim
          Hi Win,
          I buy Xiaomi Smart Plug in TW Country.
          I think this Xiaomi Smart Plug model is same.
          modelid: "lumi.plug.mitw01" = "lumi.plug" (model: "lumi.plug.mitw01" for TW Country version)
          Add Support this lumi.plug.mitw01 model?
            You already opened the request here:https://github.com/dresden-elektroni...in/issues/2094. There is nothing I can do for it then wait for the response of the github. Once the REST-API is updated, I will update the plugin with support for it if needed. Most probably the plugin will work without the need for updating.
            Wim
            -- Wim
