JowiHue Beta 2.0.4.5
This is a sticky topic.
  • #91
    New beta 2.04.4 released. Check first post for details
    -- Wim
    • #92
      New beta 2.0.4.5 is released, this is the release candidate
      -- Wim
      • #93
        Sooooo.... I upgraded from 2.0.3.3 (I think) to 2.0.4.5 without reading the release notes. Whoops, that was dumb of me. Does this log look like it succeeded or failed? I see both failures and successes and am not sure which is the end result. I have daily backups of HS3 so if I need to revert it shouldn't be a problem. Thanks in advance!
        Aug-20 6:21:28 PM JowiHue ============================================================ ================
        Aug-20 6:21:28 PM JowiHue ========== Conversion was succesfull, proceeding normal execution ==========
        Aug-20 6:21:28 PM JowiHue =============== Ending conversion JowiHue devices - step 2 =================
        Aug-20 6:21:28 PM JowiHue ============================================================ ==================
        Aug-20 6:21:28 PM JowiHue =============== Starting conversion JowiHue devices - step 2 =================
        Aug-20 6:21:28 PM JowiHue ============================================================ ==================================
        Aug-20 6:21:28 PM JowiHue 1 Animations available for use in this plugin
        Aug-20 6:21:28 PM JowiHue 7 Local scenes available for use in the JowiHue plugin
        Aug-20 6:21:28 PM JowiHue 25 Presets available for use in the JowiHue plugin
        Aug-20 6:21:28 PM JowiHue -------------------------------------Plugin info ---------------------------------------------
        Aug-20 6:21:28 PM JowiHue 2 Generic status sensor found on bridge 'Philips hue'
        Aug-20 6:21:28 PM JowiHue 1 Daylight sensor found on bridge 'Philips hue'
        Aug-20 6:21:28 PM JowiHue 1 Lightlevel sensor(s) found on bridge 'Philips hue' with 1 supporting HS device(s)
        Aug-20 6:21:28 PM JowiHue 1 Temperature sensor(s) found on bridge 'Philips hue' with 1 supporting HS device(s)
        Aug-20 6:21:28 PM JowiHue 1 Motion sensor(s) found on bridge 'Philips hue' with 1 supporting HS device(s)
        Aug-20 6:21:28 PM JowiHue Bridge Philips hue is at version 1933087030 of type BSB002
        Aug-20 6:21:28 PM JowiHue 24 Groups available on bridge 'Philips hue'
        Aug-20 6:21:28 PM JowiHue 17 lights and/or plugs connected to bridge 'Philips hue'
        Aug-20 6:21:28 PM JowiHue -------------------------------------Bridge info ---------------------------------------------
        Aug-20 6:21:27 PM JowiHue removed orphaned parentdevice 868
        Aug-20 6:21:27 PM JowiHue removed orphaned parentdevice 867
        Aug-20 6:21:27 PM JowiHue removed orphaned parentdevice 866
        Aug-20 6:21:27 PM JowiHue removed orphaned parentdevice 865
        Aug-20 6:21:23 PM JowiHue Error: (FindBridgesSelf)::Object reference not set to an instance of an object.
        Aug-20 6:21:21 PM JowiHue Importing SensorModels
        Aug-20 6:21:21 PM JowiHue Importing SensorTypes
        Aug-20 6:21:21 PM JowiHue Importing lampTypes
        Aug-20 6:21:21 PM JowiHue ============================================================ ================
        Aug-20 6:21:21 PM JowiHue =============== replace HSPI_JowiHue.exe with old version!! ================
        Aug-20 6:21:21 PM JowiHue =============== Check the logs and restore HS database ================
        Aug-20 6:21:21 PM JowiHue =============== Errors have occured during conversion! ================
        Aug-20 6:21:21 PM JowiHue =============== Ending conversion JowiHue devices - step 1 =================
        Aug-20 6:21:18 PM JowiHue Error: (ConvertDevices)::Error occured converting dv.name(hs) Column 'uniqueid' is constrained to be unique. Value '00:17:88:01:02:63:0c:34' is already present.
        Aug-20 6:21:18 PM JowiHue Error: (ConvertDevices)::Error occured converting dv.name(hs) Column 'uniqueid' is constrained to be unique. Value '00:17:88:01:02:88:41:ce' is already present.
        Aug-20 6:21:18 PM JowiHue Error: (ConvertDevices)::Error occured converting dv.name(hs) Column 'uniqueid' is constrained to be unique. Value '00:17:88:01:02:88:41:cf' is already present.
        Aug-20 6:21:18 PM JowiHue Error: (ConvertDevices)::Error occured converting dv.name(hs) Column 'uniqueid' is constrained to be unique. Value '00:17:88:01:02:8f:88:90' is already present.
        Aug-20 6:21:12 PM JowiHue ============================================================ ================
        Aug-20 6:21:12 PM JowiHue ============= Starting conversion JowiHue devices - step 1 =================
        Aug-20 6:21:11 PM Plug-In Finished initializing plug-in JowiHue
        Aug-20 6:21:11 PM Starting Plug-In JowiHue loaded in 547 milliseconds
        Aug-20 6:21:10 PM Starting Plug-In Plugin JowiHue started successfully in 288 milliseconds
        Aug-20 6:21:10 PM JowiHue InitIO:Plugin basic initialisation done
        Aug-20 6:21:10 PM JowiHue Starting plugin JowiHue 2.0.4.5 on Windows
        Aug-20 6:21:10 PM Starting Plug-In Initializing plugin JowiHue ...
        • #94
          Always read the notes when installing beta plugins.... not only for this plugin
          It looks like the conversion found 4 devices that were doubled. with these lines:
          In the next step the plugin sees the same (I think) 4 devices and removes it:
          JowiHue removed orphaned parentdevice xxx
          My guess is that you are good to go. But for a double check, restart the plugin and check if it runs without errors. If you see errors you better restart Homeseer with the old database. I will update the error messages here, so it will more explain possible causes....
          If you did not prepare the backup, homeseer has enabled the automatic backup. You can restore the old version by checking the \Data directory. In this directory you will find several versions of the HomeSeer database. Stop HomeSeer and check for the file dated before Aug-20 6:21:10. Rename the current datase to a different name and rename the backup to the corrent database.
          Restore the plugin to the old version - this is to be found in the updates3 folder, unless you upgraded HS3 also, in that case you should disable the plugin and reinstall the production version.
          Let me know?
          Wim
          -- Wim
          • #95
            I knowwwww I knowwww. I got lazy yesterday and applied the "Wim's updates are always rock solid" mentality. The one time I don't take ten seconds to read it is when a big architectural changes happens, LOL.
            Here's my plugin's startup log. I do see one object reference error.
            Aug-21 8:27:41 AM JowiHue ============================================================ ==================================
            Aug-21 8:27:41 AM JowiHue 1 Animations available for use in this plugin
            Aug-21 8:27:41 AM JowiHue 7 Local scenes available for use in the JowiHue plugin
            Aug-21 8:27:41 AM JowiHue 25 Presets available for use in the JowiHue plugin
            Aug-21 8:27:41 AM JowiHue -------------------------------------Plugin info ---------------------------------------------
            Aug-21 8:27:41 AM JowiHue 2 Generic status sensor found on bridge 'Philips hue'
            Aug-21 8:27:41 AM JowiHue 1 Daylight sensor found on bridge 'Philips hue'
            Aug-21 8:27:41 AM JowiHue 1 Lightlevel sensor(s) found on bridge 'Philips hue' with 1 supporting HS device(s)
            Aug-21 8:27:41 AM JowiHue 1 Temperature sensor(s) found on bridge 'Philips hue' with 1 supporting HS device(s)
            Aug-21 8:27:41 AM JowiHue 1 Motion sensor(s) found on bridge 'Philips hue' with 1 supporting HS device(s)
            Aug-21 8:27:41 AM JowiHue Bridge Philips hue is at version 1933087030 of type BSB002
            Aug-21 8:27:41 AM JowiHue 24 Groups available on bridge 'Philips hue'
            Aug-21 8:27:41 AM JowiHue 17 lights and/or plugs connected to bridge 'Philips hue'
            Aug-21 8:27:41 AM JowiHue -------------------------------------Bridge info ---------------------------------------------
            Aug-21 8:27:35 AM JowiHue Error: (FindBridgesSelf)::Object reference not set to an instance of an object.
            Aug-21 8:27:32 AM Plug-In Finished initializing plug-in JowiHue
            Aug-21 8:27:32 AM Starting Plug-In JowiHue loaded in 765 milliseconds
            Aug-21 8:27:32 AM Starting Plug-In Plugin JowiHue started successfully in 338 milliseconds
            Aug-21 8:27:32 AM JowiHue InitIO:Plugin basic initialisation done
            Aug-21 8:27:32 AM JowiHue Starting plugin JowiHue 2.0.4.5 on Windows
            Aug-21 8:27:32 AM Starting Plug-In Initializing plugin JowiHue ...
            Aug-21 8:27:32 AM Info Plugin JowiHue has connected. IP:127.0.0.1:57889
            Aug-21 8:27:19 AM Info Plugin JowiHue with instance: has disconnected
            Aug-21 8:27:19 AM JowiHue Error: (ShutdownIO)::Error ending JowiHue Plug-In
            Aug-21 8:27:19 AM Plug-In Shutting down Plug-In: JowiHue
            • #96
              Could you do two things for me? First, post an image of the advanced tab of the bridge device properties. I am wondering if the conversion did something wrong with the properties of this device. Is the object reference error occurring only during startup?
              Second, send me a detailed trace of the plugin? Follw these steps:
              1. set detailed trace and log to file options in the configuration page of the plugin
              2. stop and start the plugin and let the plugin run for say 10 minutes - this should catch the error and the first recurring routines
              3. Disable detailed trace and log to file options
              4. Send me the log file (located in the \Logs subdirectory of HS3 as JowiHue.log)
              Send the file to jowihue at ziggo dot nl?
              Wim
              -- Wim
              • #97
                Log file on the way...
