Trådfri motion sensor Gen2
    Hi.
    Has anyone had any luck with the new motion sensor (with the night/day and 30%/100% settings) ?
    It detects motion i phoscon, but not in the JowiHue plugin - status for the root device just says 'No Status (Root)' - while the phoscon has 'Motion: Detected'
    The motion is not shown in the root device, but one of its subdevices. best way to check that is make sure the device manage page of HS has show in groups enabled
    -- Wim
      Hi, sorry for the late answer.
      If that is the case, some devices are missing from the Gen2 i would think
Name:	2019-07-25 22_34_46.png
        This is a screenshot of the root devices status graphics page.
Name:	2019-07-25 22_36_19.png
          yes, there sure are missing some.....what do you get when pressing the JowiHue tab? is there a json available? also, I would like to see the advanced tab of this device. This is not at all supposed to happen...
          Did you add this device before or after the conversion to the beta?
          -- Wim
            Good morning.
            The device was added after the conversion.
            The JSON from the JH-tab looks like this:
            ZHAPresence
            **************************** Object info *****************************
            "state": {
            "presence": false,
            "lastupdated": "2019-07-25T20:53:51",
            "dark": true
            "config": {
            "on": true,
            "alert": "none",
            "battery": 87,
            "duration": 60,
            "delay": 180,
            "reachable": true
            "name": "TRÅDFRI Motion sensor",
            "type": "ZHAPresence",
            "modelid": "TRADFRI motion sensor",
            "manufacturername": "IKEA of Sweden",
            "swversion": "2.0.022",
            "uniqueid": "14:b4:57:ff:fe:7b:91:75-01-0006",
            "ep": 1,
            "etag": "73ce22fed44772b36f3a7f9f9935d22e"
            ************************* End Object info ***************************
              And, the advanced page looks like this:
Name:	2019-07-26 06_23_38-.png
                Also, i would think that Deconz/phoscon has some sort of stock in this issue also.
                The device has seized direct control of a bulb, the bulb still works as before - but the sensor also controls it directly.
                I did not notice this before, since it is a lamp outside of the house - sorry.
                  I will have to check a few things here, I have gen1 tradfri motion sensors here, will check here if new device creation go well here. It should have create a seperate motion device.
                  But this probably will happen after the weekend ok?
                  -- Wim
                    Perfectly fine.
                    Take your time
                      Just bought a few bulbs to test something else, when added to the beta directly - they don't get a root device. Just sharing, it might help you in some way
                        If it are white only devices, they will not get a root device indeed. Only devices that have a colotemperature or color capability - that do need more then one device only - will get a root device. So I am a bit guessing you have added white only devices?
                        -- Wim
                          Correct! That makes sense.
                          I just saw a pattern and thought to share
                            But, when upgrading it creates root devices for white only devices.
                            i have old white devices with root devices, and new ones without.
                              Will try to retest this here and check.... Thought I caught this earlier!
                              -- Wim
