Hi,
I'm new to deconz and JowiHue, but have gotten everything up and running.
Had some problems with updating the firmware of Deconz, but after solving that I did a complete re-install of everything.
Including JowiHue( manually deleted the files mentioned in a post here earlier).
After getting everything back up and running, I have been able to get all my test devices in HS3. 1 Bulb and 2 remotes, but after there,it has just gone downhill.
At first when I included my first remote, 1 device was created and when I pressed the buttons the corresponding value showed. But after a while, a second device have been created(battery). After this happened, the value/state shown on the root device is just: "No Status (Root)". And nothing is happening when I press the buttons.
BUT, the Last Change time changes, so something is registered.
I also have a error in the log that shows at regular interval (30 seconds).
Restarting the Plugin does not help.
Anyone have any suggestions for me?
aug-13 22:04:17 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 22:03:47 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 22:03:17 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 22:02:47 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 22:02:17 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 22:01:47 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 22:01:17 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 22:00:47 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 22:00:17 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 21:59:47 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 21:59:17 | JowiHue | Battery device created for sensor TRÅDFRI remote control 2 |
aug-13 21:59:17 | JowiHue | Device TRADFRI remote control renamed to TRÅDFRI remote control 2 |
aug-13 21:59:16 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 21:58:57 | JowiHue | Scanning New lights started. If New lights are found the plugin will add them automatically |
aug-13 21:58:47 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 21:58:16 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 21:57:46 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 21:57:16 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 21:56:46 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 21:56:16 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 21:55:46 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 21:55:17 | JowiHue | Creating device for TRADFRI remote control of type ZHASwitch |
aug-13 21:55:16 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 21:54:46 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 21:54:16 | JowiHue | Error: (UpdateLights)::Object reference not set to an instance of an object. |
aug-13 21:53:46 | JowiHue | Error: (UpdateLights):Start:Object reference not set to an instance of an object. |
aug-13 21:53:16 | JowiHue | Error: (UpdateLights):Start:Object reference not set to an instance of an object. |
aug-13 21:52:46 | JowiHue | Error: (UpdateLights):Start:Object reference not set to an instance of an object. |
aug-13 21:52:16 | JowiHue | Error: (UpdateLights):Start:Object reference not set to an instance of an object. |
aug-13 21:51:46 | JowiHue | Error: (UpdateLights):Start:Object reference not set to an instance of an object. |
aug-13 21:51:16 | JowiHue | Error: (UpdateLights):Start:Object reference not set to an instance of an object. |
aug-13 21:51:16 | JowiHue | Refresh bridge conbee set to 30 seconds after establishing direct connection |
aug-13 21:51:15 | JowiHue | socket opened for conbee on 192.168.10.4:443 |
aug-13 21:51:15 | JowiHue | Enabled Colour Temperature control for group All Lights |
aug-13 21:51:15 | JowiHue | Devices added for light Eine Light 1 |
aug-13 21:51:15 | JowiHue | Created new colourtemperature device for Eine Light 1 |
aug-13 21:51:12 | JowiHue | recreating bridge device conbee |
aug-13 21:50:40 | JowiHue | InitIO:Plugin basic initialisation done |
aug-13 21:50:40 | JowiHue | Starting plugin JowiHue 2.0.4.4 on Windows |
aug-13 21:50:29 | JowiHue | JowiHue Plugin is stopped. Thanks for using it :-) |
aug-13 21:50:29 | JowiHue | disconnecting bridge conbee |
aug-13 21:50:06 | JowiHue | Error: (UpdateLight)::Object reference not set to an instance of an object. |
aug-13 21:49:45 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:44 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:43 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:42 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:36 | JowiHue | Error: (UpdateLight)::Object reference not set to an instance of an object. |
aug-13 21:49:36 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:35 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:34 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:33 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:30 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:29 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:28 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:23 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:22 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:16 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:15 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:14 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:13 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:12 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:11 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:10 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:06 | JowiHue | Battery device created for sensor TRÅDFRI remote control 1 |
aug-13 21:49:06 | JowiHue | Device TRADFRI remote control renamed to TRÅDFRI remote control 1 |
aug-13 21:49:06 | JowiHue | Error: (AddLight)::Column 'BridgeSerial, ID' is constrained to be unique. Value '00212EFFFF02F513, 1' is already present. |
aug-13 21:49:06 | JowiHue | Error: (UpdateLight)::Object reference not set to an instance of an object. |
aug-13 21:49:06 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:49:05 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:48:50 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:48:49 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:48:48 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:48:47 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:48:46 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:48:45 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:48:41 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:48:40 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:48:39 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:48:37 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:48:36 | JowiHue | Error: (UpdateLight)::Object reference not set to an instance of an object. |
aug-13 21:48:36 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:48:31 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:48:30 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:48:06 | JowiHue | Error: (UpdateLight)::Object reference not set to an instance of an object. |
aug-13 21:47:36 | JowiHue | Error: (UpdateLight)::Object reference not set to an instance of an object. |
aug-13 21:47:06 | JowiHue | Error: (UpdateLight)::Object reference not set to an instance of an object. |
aug-13 21:46:36 | JowiHue | Error: (UpdateLight)::Object reference not set to an instance of an object. |
aug-13 21:46:06 | JowiHue | Error: (UpdateLight)::Object reference not set to an instance of an object. |
aug-13 21:45:38 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:45:36 | JowiHue | Error: (UpdateLight)::Object reference not set to an instance of an object. |
aug-13 21:45:06 | JowiHue | Error: (UpdateLight)::Object reference not set to an instance of an object. |
aug-13 21:44:50 | JowiHue | Creating device for TRADFRI remote control of type ZHASwitch |
aug-13 21:44:36 | JowiHue | Error: (UpdateLight)::Object reference not set to an instance of an object. |
aug-13 21:44:35 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:44:33 | JowiHue | Error: (UpdateLight):Updating light:Object reference not set to an instance of an object. |
aug-13 21:44:06 | JowiHue | Error: (UpdateLight)::Object reference not set to an instance of an object. |
aug-13 21:43:33 | JowiHue | Scanning New lights started. If New lights are found the plugin will add them automatically |
aug-13 21:41:06 | JowiHue | Refresh bridge conbee set to 30 seconds after establishing direct connection |
aug-13 21:41:05 | JowiHue | socket opened for conbee on 192.168.10.4:443 |
aug-13 21:41:04 | JowiHue | Error: (RefreshDevices):Start:Object reference not set to an instance of an object. |
aug-13 21:41:02 | JowiHue | Registration of bridge was succesfull |
aug-13 21:40:09 | JowiHue | Error: (HSEvent)::Error running config change:Object reference not set to an instance of an object. |
aug-13 21:40:09 | JowiHue | Extra info: 0-0-154-2 |
aug-13 21:40:08 | JowiHue | Extra info: 0-0-155-2 |
aug-13 21:40:08 | JowiHue | Error: (HSEvent)::Error running config change:Object reference not set to an instance of an object. |
aug-13 21:39:47 | JowiHue | ============================================================ ================================ |
aug-13 21:39:47 | JowiHue | Please register this bridge in the configuration page |
aug-13 21:39:47 | JowiHue | Info: Unregistered bridge found at IP address 192.168.10.4 |
aug-13 21:39:47 | JowiHue | ------------------------------------------NEW Bridge --------------------------------------- |
aug-13 21:39:17 | JowiHue | Warning: Did you remove a light from the bridge but left the device? Re-add the light to the bridge and your events are save |
aug-13 21:39:17 | JowiHue | Warning: Or remove the devices belonging to this light |
aug-13 21:39:17 | JowiHue | Warning: Orphaned Light VindusLys Loftstue found, not found on any connected bridge |
aug-13 21:39:16 | JowiHue | Importing SensorModels |
aug-13 21:39:16 | JowiHue | Importing SensorTypes |
aug-13 21:39:16 | JowiHue | Importing lampTypes |
aug-13 21:39:15 | JowiHue | InitIO:Plugin basic initialisation done |
aug-13 21:39:14 | JowiHue | Starting plugin JowiHue 2.0.4.4 on Windows |
aug-13 21:18:29 | JowiHue | JowiHue Plugin is stopped. Thanks for using it :-) |
aug-13 21:18:29 | JowiHue | socket closed for bridge conbee on 192.168.10.4:443 |
aug-13 21:18:29 | JowiHue | disconnecting bridge conbee |
