20/8 Philips update broke the plugin?
  • B50int
    Originally posted by B50int View Post
    Wim
    I am not currently using any betas. Happy to try it but as so often happens with home automation, it fails just before you go away for a few days! I will get a chance on Friday hopefully.
    Thanks for the pointer. Will report back...
    Jon
    Wim,
    Just installed your Beta and its all come back alive with no more issues that i can detect.
    Thanks for your great response, support and of course- the plugin! It's become an important integral part of my setup.
    Jon
  • w.vuyk
    Originally posted by NAB View Post
    Sadly not - all my bulbs are marked 'unreachable' in HS3 and nothing turns on or off.
    Is this after updatng to the beta?
  • NAB
    Originally posted by w.vuyk View Post
    The plugin will still be able to put lights on and off, so events should work.
  • w.vuyk
    Originally posted by logman View Post
    Wait, don't you mean Signify? I noticed you used Lightify in the release notes for 2.0.4.5 too, but the Lightify name belongs to OSRAM. Philips Lighting (the parent company of Philips Hue) is changing to Signify.
    Hopefully you used the right name in the code rewrite, but just wanted to make sure..
    --Barry
    Barry,
    You are right.. I am getting old, starting to confuse things LOL. I do mean Signify. And if I confused also it in my plugin... it is working here, received the update last week already as part of beta testing things, so I had to solve it for myself the hard way already
  • shadowshaker
    OK will open a new thread thanks
  • logman
    You are a victim of the Philips name change to Lightify.
    --Barry
  • w.vuyk
    The plugin will still be able to put lights on and off, so events should work. A work around for the number of errorlines is changing the polling frequency in the configuration page to a high value. Each refresh causes the errorline. As you are way it is less important maybe for devices to update to new status (they probably even wont change...) Set the polling frequency rate to say 120 to update only once per 2 minutes?
  • B50int
    Yuch, they did this bridge update sooner then I expected. Was hoping they would do the production update a few weeks later - or are you in the beta program of Philips Hue too?
    You are a victim of the Philips name change to Signify. This is already solved in the latest beta. But be aware, make a backup before you install the beta. I think most issues are solved in the beta, but just be sure, have that backup in place. Be sure to read the notes here as it is a one way update, going back is including a HS database restore.
    Let me know if this works out?
    Wim
    Wim
    Jon
  • w.vuyk
    Originally posted by shadowshaker View Post
    Same here - plug in not working and I am getting these errors
    Error: (BuildBridgeTab)::web Maintenance:Object reference not set to an instance of an object.
    I removed the hub on the bridge and lights page of the plug in and tried re=adding but same error
    Alan
    shadowshaker
    I do not think you have the same issue. The error you show is only shown when one opens the bridge maintenance page. The plugin probably functions fine besides that error. It is also not a reason to start removing devices for it. It is probably best to start a new thread for this. In this new thread, let me know which bridge you are using and wich slider you try to open that causes this error to be logged? We will then take it from there.
    Wim
  • w.vuyk
    Wim
    My Philips hub auto updated today, and now the bridge is unreachable.
    i have tried disabling the plugin, deleting the hub device and rescanning but the same problem arises.
    The log log is awash with errors from the plugin but of course the hue app works just fine....!
    Jon
    Wim
  • shadowshaker
    Alan
  • B50int
    started a topic 20/8 Philips update broke the plugin?
    Wim
    Jon
