All,
Philips is rolling out an update to their customers of Philips Hue bridges that changes the name of the company. This plugin uses this name to distinguish between bridges.
After the name change the current production version (2.0.3.3) and earlier versions of the plugin will throw errors because of this.
Philips started rolling out this update a lot sooner then I expected, so the plugin with the solution is still in beta
The current beta of the plugin (2.0.4.5 and higher) has been updated to address this issue.
To solve this issue, the upgrade to the beta is needed. But be aware this is a one way upgrade as devices in the HS database are all changed.. Have a backup of the Homeseer database as well as the old version of the plugn ready. This beta version is the release candidate, and also for the new release, the upgrade will be a one way upgrade as the devices structure changes.
Wim
Update September 6: I have send the release 2.1.0.0 to HST to publish. to do this I had to remove the beta version, From now on, please check for the 2.1.0.0 version of the plugin
Wim
