Hey Wim,
You'll probably know the cure for this.
I had to restore my schedule from a backup and the plug broke. Restarted HS, Hue bridge, removed the bridge as the plugin couldn't see it, rescanned, got it back communicating okay.
Then I get this for most all lights:
Error: (SetDeviceByUserRequest):Start:SDBUR light or group off stopanimations -----Object reference not set to an instance of an object.
On startup I get:
And I can't work out what the problem is as it looks to me as if it's seeing all the lights but isn't tying them up as it should for some reason.
Any pointers would be appreciated.
K.
On startup I get:
Aug-21 21:08:12 | JowiHue | ============================================================ ================================== |
Aug-21 21:08:12 | JowiHue | 0 Animations available for use in this plugin |
Aug-21 21:08:12 | JowiHue | 1 Local scenes available for use in the JowiHue plugin |
Aug-21 21:08:12 | JowiHue | 22 Presets available for use in the JowiHue plugin |
Aug-21 21:08:12 | JowiHue | -------------------------------------Plugin info --------------------------------------------- |
Aug-21 21:08:12 | JowiHue | Bridge Philips Hue 2.0 is at version of type on a |
Aug-21 21:08:12 | JowiHue | 10 Groups available on bridge 'Philips Hue 2.0' |
Aug-21 21:08:12 | JowiHue | 38 lights and/or plugs connected to bridge 'Philips Hue 2.0' |
Aug-21 21:08:12 | JowiHue | -------------------------------------Bridge info --------------------------------------------- |
Aug-21 21:08:12 | JowiHue | Warning: Device 953 with name Daylight seems to be damaged! Will try to repair |
Aug-21 21:08:12 | JowiHue | Warning: JowiHue Plugin is not yet in ready state. Command not executed, please resend after initialisation finished |
K.
