Several JowiHue devices apperaing in the device list
  • Several JowiHue devices apperaing in the device list
    Seems like I have a lot of JowiHue devices that does not make sense, Shall I just delete them?
    By the looks of these the devices were created, but the creation process did not finiish properly? You can delete them, to be on the save side, make sure you stop the plugin first?
    Wim
    -- Wim
      Well, I disabled it but when enabling it again they were recreated:
      Aug-27 9:10:15 AM JowiHue Unknown modelid RM01 for sensor Bad2. Default button event values are applied
      Aug-27 9:10:15 AM JowiHue Device created for sensor Bad2 on bridge Phoscon-GW with ID 9
      Aug-27 9:10:15 AM JowiHue Unknown model sensor found Bad2 model RM01 type ZHASwitch. Default values used
      Aug-27 9:10:15 AM JowiHue Creating device for Bad2 of type ZHASwitch
      Aug-27 9:10:15 AM JowiHue Device created for sensor Bad2 on bridge Phoscon-GW with ID 8
      Aug-27 9:10:15 AM JowiHue Unknown modelid RM01 for sensor Sov1. Default button event values are applied
      Aug-27 9:10:15 AM JowiHue Device created for sensor Sov1 on bridge Phoscon-GW with ID 7
      Aug-27 9:10:15 AM JowiHue Unknown model sensor found Sov1 model RM01 type ZHASwitch. Default values used
      Aug-27 9:10:15 AM JowiHue Creating device for Sov1 of type ZHASwitch
      Aug-27 9:10:15 AM JowiHue Device created for sensor Sov1 on bridge Phoscon-GW with ID 6
      Aug-27 9:10:15 AM JowiHue Unknown modelid RM01 for sensor Kjøkken 1. Default button event values are applied
      Aug-27 9:10:15 AM JowiHue Device created for sensor Kjøkken 1 on bridge Phoscon-GW with ID 5
      Aug-27 9:10:15 AM JowiHue Unknown model sensor found Kjøkken 1 model RM01 type ZHASwitch. Default values used
      Aug-27 9:10:15 AM JowiHue Creating device for Kjøkken 1 of type ZHASwitch
      Aug-27 9:10:15 AM JowiHue Device created for sensor Kjøkken 1 on bridge Phoscon-GW with ID 4
      Aug-27 9:10:15 AM JowiHue Device created for sensor Kjøkken 1 on bridge Phoscon-GW with ID 3
      Aug-27 9:10:15 AM JowiHue Unknown modelid RM01 for sensor Sov3. Default button event values are applied
      Aug-27 9:10:15 AM JowiHue Device created for sensor Sov3 on bridge Phoscon-GW with ID 22
      Aug-27 9:10:15 AM JowiHue Unknown model sensor found Sov3 model RM01 type ZHASwitch. Default values used
      Aug-27 9:10:15 AM JowiHue Creating device for Sov3 of type ZHASwitch
      Aug-27 9:10:15 AM JowiHue Unknown modelid RM01 for sensor Bod. Default button event values are applied
      Aug-27 9:10:15 AM JowiHue Device created for sensor Bod on bridge Phoscon-GW with ID 21
      Aug-27 9:10:15 AM JowiHue Unknown model sensor found Bod model RM01 type ZHASwitch. Default values used
      Aug-27 9:10:15 AM JowiHue Creating device for Bod of type ZHASwitch
      Aug-27 9:10:15 AM JowiHue Unknown modelid RM01 for sensor Entre. Default button event values are applied
      Aug-27 9:10:15 AM JowiHue Device created for sensor Entre on bridge Phoscon-GW with ID 20
      Aug-27 9:10:15 AM JowiHue Unknown model sensor found Entre model RM01 type ZHASwitch. Default values used
      Aug-27 9:10:15 AM JowiHue Creating device for Entre of type ZHASwitch
      Aug-27 9:10:15 AM JowiHue Device created for sensor Kjøkken 1 on bridge Phoscon-GW with ID 2
      Aug-27 9:10:15 AM JowiHue Device created for sensor Entre on bridge Phoscon-GW with ID 19
      Aug-27 9:10:15 AM JowiHue Device created for sensor Entre on bridge Phoscon-GW with ID 18
      Aug-27 9:10:15 AM JowiHue Device created for sensor Entre on bridge Phoscon-GW with ID 17
      Aug-27 9:10:15 AM JowiHue Unknown modelid RM01 for sensor Sov2. Default button event values are applied
      Aug-27 9:10:15 AM JowiHue Device created for sensor Sov2 on bridge Phoscon-GW with ID 16
      Aug-27 9:10:15 AM JowiHue Unknown model sensor found Sov2 model RM01 type ZHASwitch. Default values used
      Aug-27 9:10:15 AM JowiHue Creating device for Sov2 of type ZHASwitch
      Aug-27 9:10:15 AM JowiHue Unknown modelid RM01 for sensor Kjøkkenbenk. Default button event values are applied
      Aug-27 9:10:15 AM JowiHue Device created for sensor Kjøkkenbenk on bridge Phoscon-GW with ID 15
      Aug-27 9:10:15 AM JowiHue Unknown model sensor found Kjøkkenbenk model RM01 type ZHASwitch. Default values used
      Aug-27 9:10:15 AM JowiHue Creating device for Kjøkkenbenk of type ZHASwitch
      Aug-27 9:10:15 AM JowiHue Device created for sensor Kjøkkenbenk on bridge Phoscon-GW with ID 14
      Aug-27 9:10:15 AM JowiHue Device created for sensor Kjøkkenbenk on bridge Phoscon-GW with ID 13
      Aug-27 9:10:15 AM JowiHue Device created for sensor Kjøkkenbenk on bridge Phoscon-GW with ID 12
      Aug-27 9:10:15 AM JowiHue Unknown modelid RM01 for sensor Bad1. Default button event values are applied
      Aug-27 9:10:15 AM JowiHue Device created for sensor Bad1 on bridge Phoscon-GW with ID 11
      Aug-27 9:10:15 AM JowiHue Unknown model sensor found Bad1 model RM01 type ZHASwitch. Default values used
      Aug-27 9:10:15 AM JowiHue Creating device for Bad1 of type ZHASwitch
      Aug-27 9:10:15 AM JowiHue Device created for sensor Bad1 on bridge Phoscon-GW with ID 10
      Aug-27 9:10:15 AM JowiHue Refresh bridge Phoscon-GW set to 30 seconds after establishing direct connection
      Aug-27 9:10:14 AM JowiHue socket opened for Phoscon-GW on 192.168.50.50:443
      Aug-27 9:10:11 AM JowiHue ==============================================================================================
      Aug-27 9:10:11 AM JowiHue 0 Animations available for use in this plugin
      Aug-27 9:10:11 AM JowiHue 0 Local scenes available for use in the JowiHue plugin
      Aug-27 9:10:11 AM JowiHue 22 Presets available for use in the JowiHue plugin
      Aug-27 9:10:11 AM JowiHue -------------------------------------Plugin info ---------------------------------------------
      Aug-27 9:10:11 AM JowiHue 1 Daylight sensor found on bridge 'Phoscon-GW'
      Aug-27 9:10:11 AM JowiHue 21 Remote switch found on bridge 'Phoscon-GW'
      Aug-27 9:10:11 AM JowiHue Bridge Phoscon-GW is at version 2.5.65 of type deCONZ on a ConBee
      Aug-27 9:10:11 AM JowiHue 20 Groups available on bridge 'Phoscon-GW'
      Aug-27 9:10:11 AM JowiHue 16 lights and/or plugs connected to bridge 'Phoscon-GW'
        It is all one model the log is mentioning here. The RM01. What kind of sensor is this? I might have to add it to the supported list? So I will need to have a bit more info on this model.
        Is the list different now? What when you operate one of the switches, does the value change to anything different then 0?
        -- Wim
          It is a Busch Jaeger Zigbee ligth dimmer. I'm not able to operate the switch now, but I can check tonight when I'm back home
          https://www.busch-jaeger.de/en/produ...ee-light-link/
            Owww.... I have one of these devices from a long time ago.... never tried to connect it anymore as it was not working when I started with deCONZ. There are some differences in the shape of the buttons, but I might test it again here... if it works it might be a handy. device....
            -- Wim
              It is very handy, and it is the one of the few switches that I have found that can control several Zigbee bulbs as well as provide switch/dimming of regular lamps directly.
              However, there is one flaw and that is "scenario" control. As I can only can connect its buttons to light sources, then I'm struggling to trigger e.g. "away" mode, that also e.g. triggers z-wave actions (e.g. close the blinds). I could connect a button to set a bulb to 35% and when homeseer detects that the bulb is at 35 then the scenario is triggered, but it is a bit cumbersome.
              Any suggestions?
                I do not use the zigbee switches to directly controll bulbs. I do this with the events of Homeseer. this way I can decide wether a short press controls a bulb and a long press activates a scene, of dim up/down etc. The advantage is here that you can use the if then structure to check some extra conditions like the away mode. Also, this way I can also control non zigbee devices.
                In short, direct control of devices from switches is a last resort during disaters of HS3 for me, I make sure I know how to do this bu only configuredt once a disaster on HS3 occurs.
                *knocking wood* up til now never needed it either....
                -- Wim
