Contacting HomeSeer This Week
See more
See less
What all do I need?
  • What all do I need?
    There are some ZigBee switches I want to try. Right now my HS is mostly Insteon and some X-10. I am running HS3 on a Raspberry Pi 3b, Raspbian. I have 2 open USB ports. I want to get the hardware before I buy the plug-in so I can use the trial. Will this work as the gateway?
    https://www.amazon.com/GoControl-CECOMINOD016164-HUSBZB-1-USB-Hub/dp/B01GJ826F8/
    And besides the devices I want to control, is there anything else I need? I keep seeing deCONZ in the forum. What is that? Thanks for any reply. No hurry.
    I run it on a windows machine,
    then you need the stick
    https://phoscon.de/en/conbee2
    and the software
    https://www.dresden-elektronik.de/fu...are/pc/deconz/
    and ofcourse the plugin
    i don't know if it works on a raspberry, because i don't have that
      The hub you posted is not supported by this plugin. The plugin supports Philips Hue bridges and deCONZ gateways (Conbee or Raspbee or the RaspBee Premium card ).
      I am not sure if the deCONZ gateway software runs fine on the same raspberry as HS3 (it does run on a raspberry), maybe others can chime in to confirm if this should work?
      A link to the store (should be on amazone too, but cannot search on US amazone) https://shop.dresden-elektronik.de/w...teway-153.html
      -- Wim
