Recurring Error...
  • Recurring Error...
    Why is this happening?
    Aug-30 10:09:48 PM JowiHue Error: (CheckBridgeUpdate)::Object reference not set to an instance of an object.
    Aug-30 10:09:48 PM JowiHue Error: (CheckBridgeUpdate)::CheckBridgeUpdate Version 1.33.0
    Also seeing errors about Hue Hub. Says something like Device at xxx.xxx not recognized as a Hue Bridge. Have to disable plugin and enable again then the plugin sees the bridge again. No change in IP.
    The plugin sees an update but cannot report this correctly. Which version of the plugin are you using? The current betas stops reproting updates as Philips changed the methods and so far I have been unable to report the updates correctly.
    The update that is being reported is the change of name which I reported here: https://forums.homeseer.com/forum/li...ue-august-2019
    The second error you reported, the Philips not being recognised as Hue bridge is pointing to that issue, so I think you should install the beta version to solve this error. But please before installing this version, make the backup?
    Wim
    -- Wim
      I was using v2.0.3.3 I just installed the beta. Seeing these errors now:
      Aug-31 8:50:49 AM Updater Install/Update of package JowiHue was successful.
      Aug-31 8:50:48 AM Updater Copying file: /usr/local/HomeSeer/HSPI_JowiHue.exe.config
      Aug-31 8:50:48 AM Updater Copying file: /usr/local/HomeSeer/bin/JowiHue/WebSocket4Net.dll
      Aug-31 8:50:48 AM Updater Copying file: /usr/local/HomeSeer/bin/JowiHue/Newtonsoft.Json.dll
      Aug-31 8:50:48 AM Updater Extraction Complete.
      Aug-31 8:50:42 AM Updater Extracting files from zip file: JowiHue_images.zip
      Aug-31 8:50:42 AM Updater Warning File exists, not overwriting: \usr\local\HomeSeer\Data\JowiHue\JowiHue.db
      Aug-31 8:50:42 AM Updater Copying file: /usr/local/HomeSeer/Config/JowiHueImports.xml
      Aug-31 8:50:42 AM Updater Copying file: /usr/local/HomeSeer/html/jowihue/JowiHue.pdf
      Aug-31 8:50:42 AM Updater Copying file: /usr/local/HomeSeer/Docs/JowiHue.pdf
      Aug-31 8:50:36 AM Updater Installing package JowiHue
      Aug-31 8:50:36 AM Updater Update downloaded successfully
      Aug-31 8:50:27 AM Updater Downloading update: JowiHue
      Aug-31 8:50:27 AM Warning Update is not configured properly in updater.txt file, missing interface name.
      Aug-31 8:50:27 AM Updater Starting download of updates
      Time will tell if beta solves the problems.
      Don
        Still seeing these errors after installing beta:
        Aug-31 9:09:48 AM JowiHue Error: (CheckBridgeUpdate)::Object reference not set to an instance of an object.
        Aug-31 9:09:48 AM JowiHue Error: (CheckBridgeUpdate)::CheckBridgeUpdate Version 1.33.0
          Did you disable/enable the plugin after the update? The updater no longer does that. The warning about the updater.txt file is a known problem with the updater. It can be ignored.
            Thought I caught them all.... it will be removed in the next beta
            Thanks for letting me know!
            Wim
            -- Wim
              After disabling/enabling it's now flooding the log with this:
              Aug-31 2:23:09 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:23:06 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:23:03 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:23:00 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:57 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:54 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:51 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:48 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:45 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:42 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:39 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:36 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:33 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:30 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:27 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:24 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:21 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:18 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:15 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:12 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:09 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:06 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:03 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:22:00 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:57 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:54 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:51 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:48 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:45 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:42 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:39 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:36 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:33 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:30 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:27 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:24 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:21 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:18 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:15 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:12 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:09 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:06 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:03 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:21:00 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:57 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:54 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:51 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:48 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:45 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:42 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:39 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:36 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:33 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:30 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:27 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:24 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:21 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:18 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:15 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:12 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:09 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:06 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:03 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:20:00 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:57 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:54 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:51 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:48 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:45 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:42 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:39 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:36 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:33 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:30 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:27 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:24 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:21 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:18 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:15 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:12 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:09 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:06 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:03 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:19:00 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:18:57 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:18:54 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:18:51 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:18:48 PM JowiHue Error: (GetJsonCommand)::Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:18:45 PM JowiHue Error: (GetJsonCommand):Start:Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:18:42 PM JowiHue Error: (GetJsonCommand):Start:Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:18:39 PM JowiHue Error: (GetJsonCommand):Start:Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:18:36 PM JowiHue Error: (GetJsonCommand):Start:Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:18:33 PM JowiHue Error: (GetJsonCommand):Start:Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:18:30 PM JowiHue Error: (GetJsonCommand):Start:Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:18:27 PM JowiHue Error: (GetJsonCommand):Start:Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:18:24 PM JowiHue Error: (GetJsonCommand):Start:Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:18:23 PM JowiHue Error: (GetJsonCommand):Start:Error converting value "3" to type 'HSPI_JowiHue.State'. Path 'scenes.l00PPg0ifLN646O.lights[0]', line 1, position 17204.
              Aug-31 2:18:22 PM JowiHue ============================================================ ================
              Aug-31 2:18:22 PM JowiHue ========== Conversion was succesfull, proceeding normal execution ==========
              Aug-31 2:18:22 PM JowiHue =============== Ending conversion JowiHue devices - step 2 =================
              Aug-31 2:18:22 PM JowiHue ============================================================ ==================
              Aug-31 2:18:22 PM JowiHue =============== Starting conversion JowiHue devices - step 2 =================
              Aug-31 2:18:22 PM JowiHue ============================================================ ==================================
              Aug-31 2:18:22 PM JowiHue 2 Animations available for use in this plugin
              Aug-31 2:18:22 PM JowiHue 6 Local scenes available for use in the JowiHue plugin
              Aug-31 2:18:22 PM JowiHue 22 Presets available for use in the JowiHue plugin
              Aug-31 2:18:22 PM JowiHue -------------------------------------Plugin info ---------------------------------------------
              Aug-31 2:18:22 PM JowiHue Bridge Philips hue is at version of type on a
              Aug-31 2:18:22 PM JowiHue 7 Groups available on bridge 'Philips hue'
              Aug-31 2:18:22 PM JowiHue 5 lights and/or plugs connected to bridge 'Philips hue'
              Aug-31 2:18:22 PM JowiHue -------------------------------------Bridge info ---------------------------------------------
              Aug-31 2:18:15 PM JowiHue * Bridge Philips hue at 192.168.1.101:80 not connected (not reachable)
              Aug-31 2:18:15 PM JowiHue Warning: Bridge Philips hue not reachable on 192.168.1.101 is bridge powered on or IP/Port address has changed?
              Aug-31 2:18:15 PM JowiHue Cannot find bridge Philips hue on ip adress 192.168.1.101:80 marking unreachable
              Aug-31 2:18:11 PM JowiHue Importing SensorModels
              Aug-31 2:18:11 PM JowiHue Importing SensorTypes
              Aug-31 2:18:10 PM JowiHue Importing lampTypes
              Aug-31 2:18:10 PM JowiHue ============================================================ ================
              Aug-31 2:18:10 PM JowiHue =============== Conversion was succesfull, preparing step 2 ================
              Aug-31 2:18:10 PM JowiHue =============== Ending conversion JowiHue devices - step 1 =================
              Aug-31 2:18:02 PM JowiHue ============================================================ ================
              Aug-31 2:18:02 PM JowiHue ============= Starting conversion JowiHue devices - step 1 =================
              Aug-31 2:18:01 PM Plug-In Finished initializing plug-in JowiHue
              Aug-31 2:18:01 PM Starting Plug-In JowiHue loaded in 3045 milliseconds
              Aug-31 2:18:01 PM Starting Plug-In Plugin JowiHue started successfully in 1627 milliseconds
              Aug-31 2:18:01 PM JowiHue InitIO:Plugin basic initialisation done
              Aug-31 2:18:01 PM JowiHue ****** Creating table SensorModels
              Aug-31 2:18:00 PM JowiHue Starting plugin JowiHue 2.0.4.4 on Linux
              Aug-31 2:18:00 PM Starting Plug-In Initializing plugin JowiHue ...
              Aug-31 2:17:59 PM Info Plugin JowiHue has connected. IP:127.0.0.1:54164
              Aug-31 2:17:50 PM Info Plugin JowiHue with instance: has disconnected
              Aug-31 2:17:50 PM JowiHue JowiHue Plugin is stopped. Thanks for using it :-)
              Aug-31 2:17:50 PM Plug-In Shutting down Plug-In: JowiHue
                Something is wrong for sure... how did you get the (old) beta 2.0.4.4? You will need to download the 2.0.4.6 beta? I cannot even see the old one? How did you get this version?
                In this image I do not see the 2.0.4.4 version? That old version indeed does not yet solve the issue....
                Click image for larger version  Name:	2019-08-31 20_51_26-Interfaces and Add Ons.png Views:	0 Size:	184.7 KB ID:	1323625
                -- Wim
                  Installed the 2.0.4.6 plugin. Both are listed. Now seeing this, all lights gone! Seems like one thing after another....
                  Aug-31 4:13:05 PM JowiHue recreating bridge device Philips hue
                  Aug-31 4:12:41 PM JowiHue Warning: Or remove the devices belonging to this light
                  Aug-31 4:12:41 PM JowiHue Warning: Did you remove a light from the bridge but left the device? Re-add the light to the bridge and your events are save
                  Aug-31 4:12:40 PM JowiHue Warning: Orphaned Light Front Room Reading Lamp found, not found on any connected bridge
                  Aug-31 4:12:38 PM JowiHue Warning: Or remove the devices belonging to this light
                  Aug-31 4:12:38 PM JowiHue Warning: Did you remove a light from the bridge but left the device? Re-add the light to the bridge and your events are save
                  Aug-31 4:12:38 PM JowiHue Warning: Orphaned Light Hue color downlight 1 found, not found on any connected bridge
                  Aug-31 4:12:38 PM JowiHue Warning: Orphaned Light Hue Color - Livingroom Table found, not found on any connected bridge
                  Aug-31 4:12:37 PM JowiHue Warning: Or remove the devices belonging to this light
                  Aug-31 4:12:37 PM JowiHue Warning: Did you remove a light from the bridge but left the device? Re-add the light to the bridge and your events are save
                  Aug-31 4:12:37 PM JowiHue Warning: Orphaned Light Hue White - Front Room found, not found on any connected bridge
                  Aug-31 4:12:37 PM JowiHue Warning: Orphaned Light Theater Room Floor Lamp found, not found on any connected bridge
                  Aug-31 4:12:33 PM JowiHue No bridges found
                  Aug-31 4:12:30 PM JowiHue Importing SensorModels
                  Aug-31 4:12:30 PM JowiHue Importing SensorTypes
                  Aug-31 4:12:29 PM JowiHue Importing lampTypes
                  Aug-31 4:12:28 PM Plug-In Finished initializing plug-in JowiHue
                  Aug-31 4:12:28 PM Starting Plug-In JowiHue loaded in 3215 milliseconds
                  Aug-31 4:12:28 PM Starting Plug-In Plugin JowiHue started successfully in 1929 milliseconds
                  Aug-31 4:12:28 PM JowiHue InitIO:Plugin basic initialisation done
                  Aug-31 4:12:27 PM JowiHue Starting plugin JowiHue 2.0.4.6 on Linux
                    First question, do you have regained control of the lights? Are really all light devices gone, as groups seems to be there still?
                    The errors you are seeing can occur if you have been running the plugin for a long time. I remember that you had issues quite some time ago, so I guess you might be one of those long time users (thanks)
                    With the new structure of parent/child devices the 'old' issues of the plugin will be noticed more clearly now. Like "Theater Room Floor Lamp", is it still there? Or is it in the device list twice maybe? I had another user who discovered he had double devices for several lights. After removing and letting the plugin recreate devices things got solved.
                    The main thing that surprise me a bit is that the Hue bridge device gets recreated in this log. Did you remove the bridge device? In that case it logical, but otherwise you have a double device on the bridge too?
                    Wim
                    -- Wim
                      On second view, I am guessing you indeed have removed the bridge device:
                      A bit later (after the lights without bridge were found as orphaned) the bridge is added.... I think with a restart of the plugin you will be fine. It really needs a bridge to connect lights.
                      Wim
                      -- Wim
                        I see both.
                          Yuch, that is confusing... will contact HST for thos on how this can happen. Please only use the latest version
                          -- Wim
