port conflict
  • port conflict
    I just took an RPi3B+, plugged in an Aeotec Z-stick and installed a raspbee with deConz. Unfortunately they're both on port 80, my mistake. Now I can't get to HS3.
    How can I change the port on one of the two so I can access both? I really don't want to unplug the raspbee temporarily but if I have to I will.
    I believe this has been answered now in the other thread right?
    -- Wim
      It has, thank you. I kept on searching after my post and then I took a shot at it. I still have the problem that deConz just shows the "Connect" screen.
      I'm thinking of burning a new SD card with just Raspbian then installing Raspbee/deConz, then HS3 after that since they're all on the same RPi3B+
        There is an image at phoscon.de ready made for the raspbee, that you could use maybe? Don not get confused by the conbee II heading... is is for the raspbee: https://phoscon.de/en/conbee2/sdcard
        -- Wim
          w.vuyk - Cool I'll take a look at that. Thanks.
            I got both deConz and HS3 running on the same RPi3B+.
            HS3 utilizes an Aeotec z-stick and deConz runs with a raspbee attached to the GPIO. It all seems to be fine after I switched some ports. However, I'm a bit surprised that I'm well over 40% CPU usage at all times. I have no devices other than the raspbee itself, only three z-wave devices, no events, etc. If I were to build a full blown system, I expect the RPi3 would be brought to its knees. #needmorehorsepower
