A problem maybe (after update to 2.1.0.0)
    The plugin got disconnected and restarted. This happened just after I did the update.
    I will monitor this and post if it happens again.
    But I am sure the error should not have happened if things are normal
    Sep-11 12:19:09 PM JowiHue 0 Animations available for use in this plugin
    Sep-11 12:19:09 PM JowiHue 1 Local scenes available for use in the JowiHue plugin
    Sep-11 12:19:09 PM JowiHue 22 Presets available for use in the JowiHue plugin
    Sep-11 12:19:09 PM JowiHue -------------------------------------Plugin info ---------------------------------------------
    Sep-11 12:19:09 PM JowiHue 1 Daylight sensor found on bridge 'Philips hue'
    Sep-11 12:19:09 PM JowiHue Bridge Philips hue is at version 01041302 of type BSB001
    Sep-11 12:19:09 PM JowiHue 9 Groups available on bridge 'Philips hue'
    Sep-11 12:19:09 PM JowiHue 23 lights and/or plugs connected to bridge 'Philips hue'
    Sep-11 12:19:09 PM JowiHue -------------------------------------Bridge info ---------------------------------------------
    Sep-11 12:19:09 PM JowiHue ==============================================================================================
    Sep-11 12:19:06 PM JowiHue Initialisation other devices completed correctly
    Sep-11 12:19:04 PM JowiHue * Connected to bridge Philips hue at 192.168.0.157:80
    Sep-11 12:19:04 PM JowiHue Initialisation bridgedevices completed correctly
    Sep-11 12:19:03 PM Starting Plug-In Plugin JowiHue started successfully in 306 milliseconds
    Sep-11 12:19:03 PM JowiHue InitIO:Plugin basic initialisation done
    Sep-11 12:19:02 PM JowiHue Starting plugin JowiHue 2.1.0.0 on Windows
    Sep-11 12:19:02 PM Starting Plug-In Initializing plugin JowiHue ...
    Sep-11 12:19:02 PM Starting Plug-In JowiHue loaded in 15093 milliseconds
    Sep-11 12:18:55 PM Warning File does not exist: C:\Program Files (x86)\HomeSeer HS3\html\JowiHue_Configuration
    Sep-11 12:18:47 PM Info Plugin JowiHue has connected. IP:127.0.0.1:64185
    Sep-11 12:18:47 PM Warning I/O interface JowiHue is down, executable is not running, restarting ...
    Sep-11 12:18:42 PM Error Calling HSEvent in plugin JowiHue, Instance :De objectverwijzing is niet op een exemplaar van een object ingesteld.
    Sep-11 12:18:42 PM Info Plugin JowiHue with instance: has disconnected
    Sep-11 12:18:31 PM Z-Wave Device: Lightingswitch Living/Tv Switch Multilevel 1 Set to OFF
    Sep-11 12:18:31 PM Device Control Device: Lightingswitch Living/Tv Switch 1 to Off (0)
    Sep-11 12:18:31 PM Device Control Device: JowiHue JowiHue Living Tv to Off (0)
    Not sure what happend there. Were you doing some special action arond 12:18:42 after switching off the Living TV? There are rare situations where the plugin will enforce restarting itself, but that should always be done with a line in the log, pointing to the cause. Would be intersting to know what happend.
    Wim
    -- Wim
      Wim
      No nothing special. I disabled the plugin then did the update to 2.1.0.0. Enabled the plugin. And when the manager said OK I tested the plugin by pushing some lights on and off.
      It has not happened since.
        Wim it happened again (Hallo trouwens),
        It seems that whenever I start homeseer it goes bad and then goes to normal.
        Any ideas?
        Sep-12 9:14:00 AM Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/MDL/spirittToThingSpeak.vb
        Sep-12 9:14:00 AM Event Event Trigger "Timed sendSpiritValveEvery"
        Sep-12 9:12:56 AM Error Calling HSEvent in plugin JowiHue, Instance :De objectverwijzing is niet op een exemplaar van een object ingesteld.
        Sep-12 9:09:00 AM script scriptname is running
        Sep-12 9:09:00 AM Event Running script in background: C:/Program Files (x86)/HomeSeer HS3/scripts/MDL/spirittToThingSpeak.vb
        Sep-12 9:09:00 AM Event Event Trigger "Timed sendSpiritValveEvery"
        Sep-12 9:06:00 AM Energy DB Info All energy database compacting routines completed.
        Sep-12 9:06:00 AM Energy DB Info No Records. Vacuuming database to condense.
        Sep-12 9:06:00 AM Energy DB Info Energy database compaction initiated.
        Sep-12 9:05:18 AM JowiHue ==============================================================================================
        Sep-12 9:05:18 AM JowiHue 0 Animations available for use in this plugin
        Sep-12 9:05:18 AM JowiHue 1 Local scenes available for use in the JowiHue plugin
        Sep-12 9:05:18 AM JowiHue 22 Presets available for use in the JowiHue plugin
        Sep-12 9:05:18 AM JowiHue -------------------------------------Plugin info ---------------------------------------------
        Sep-12 9:05:18 AM JowiHue 1 Daylight sensor found on bridge 'Philips hue'
        Sep-12 9:05:18 AM JowiHue Bridge Philips hue is at version 01041302 of type BSB001
        Sep-12 9:05:18 AM JowiHue 9 Groups available on bridge 'Philips hue'
        Sep-12 9:05:18 AM JowiHue 23 lights and/or plugs connected to bridge 'Philips hue'
        Sep-12 9:05:18 AM JowiHue -------------------------------------Bridge info ---------------------------------------------
        Sep-12 9:05:15 AM JowiHue Initialisation other devices completed correctly
        Sep-12 9:05:13 AM JowiHue * Connected to bridge Philips hue at 192.168.0.157:80
        Sep-12 9:05:13 AM JowiHue Initialisation bridgedevices completed correctly
        Sep-12 9:05:12 AM Starting Plug-In Plugin JowiHue started successfully in 302 milliseconds
        Sep-12 9:05:12 AM JowiHue InitIO:Plugin basic initialisation done
        Sep-12 9:05:12 AM JowiHue Starting plugin JowiHue 2.1.0.0 on Windows
        Sep-12 9:05:12 AM Starting Plug-In Initializing plugin JowiHue ...
        Sep-12 9:05:12 AM Starting Plug-In JowiHue loaded in 15093 milliseconds
        Sep-12 9:04:57 AM Info Plugin JowiHue has connected. IP:127.0.0.1:60835
        Sep-12 9:04:57 AM Warning I/O interface JowiHue is down, executable is not running, restarting ...
        Sep-12 9:04:56 AM Info Plugin JowiHue with instance: has disconnected
        Sep-12 9:04:56 AM Error Calling HSEvent in plugin JowiHue, Instance :De objectverwijzing is niet op een exemplaar van een object ingesteld.
        Sep-12 9:04:31 AM Pushover 3P Pushover Notification Sent - Message Title HS3 starting
        Sep-12 9:04:30 AM Event Event Trigger "Startup_Shutdown StartupStuff"
        Sep-12 9:04:30 AM TTS Speak ():Welcome to Home-Seer
          I also experience problems after update to 2.1.0.0 yesterday.
          At first the plugin did not connect to deConz but after another restart of the plugin it connected. But then i realized I had problems with my Hue switch which now is unreachable. (I can see that it works alright in deConz).
          I can also see som kind of new problems in the startup log for the plugin regarding slow response and index out of range;
          sep-15 12:41:45 JowiHue Warning: Bridge Phoscon-GW is slow in responding. JowiHue temporary changed Refreshrate to 9 seconds for this bridge
          sep-15 12:40:40 JowiHue ============================================================ ==================================
          sep-15 12:40:40 JowiHue 2 Animations available for use in this plugin
          sep-15 12:40:40 JowiHue 6 Local scenes available for use in the JowiHue plugin
          sep-15 12:40:40 JowiHue 22 Presets available for use in the JowiHue plugin
          sep-15 12:40:40 JowiHue -------------------------------------Plugin info ---------------------------------------------
          sep-15 12:40:40 JowiHue 2 Pressure sensor(s) found on bridge 'Phoscon-GW' with 2 supporting HS device(s)
          sep-15 12:40:40 JowiHue 2 Humidity sensor(s) found on bridge 'Phoscon-GW' with 2 supporting HS device(s)
          sep-15 12:40:40 JowiHue 4 Open/Close sensor(s) found on bridge 'Phoscon-GW' with 4 supporting HS device(s)
          sep-15 12:40:40 JowiHue 1 Daylight sensor found on bridge 'Phoscon-GW'
          sep-15 12:40:40 JowiHue 1 Lightlevel sensor(s) found on bridge 'Phoscon-GW' with 1 supporting HS device(s)
          sep-15 12:40:40 JowiHue 2 Temperature sensor(s) found on bridge 'Phoscon-GW' with 2 supporting HS device(s)
          sep-15 12:40:40 JowiHue 2 Motion sensor(s) found on bridge 'Phoscon-GW' with 2 supporting HS device(s)
          sep-15 12:40:40 JowiHue 8 Remote switch(s) found on bridge 'Phoscon-GW' with 7 supporting HS device(s)
          sep-15 12:40:40 JowiHue Bridge Phoscon-GW is at version 2.5.60 of type deCONZ on a ConBee
          sep-15 12:40:40 JowiHue 12 Groups available on bridge 'Phoscon-GW'
          sep-15 12:40:40 JowiHue 33 lights and/or plugs connected to bridge 'Phoscon-GW'
          sep-15 12:40:40 JowiHue -------------------------------------Bridge info ---------------------------------------------
          sep-15 12:40:40 JowiHue Error: (RefreshDevices):Start:Indexet låg utanför gränserna för matrisen.
          sep-15 12:40:35 JowiHue Initialisation other devices completed correctly
          sep-15 12:40:24 JowiHue * Connected to bridge Phoscon-GW at 192.168.2.104:8090
          sep-15 12:40:24 JowiHue Initialisation bridgedevices completed correctly, but needed 2 retries
          sep-15 12:40:16 Starting Plug-In Plugin JowiHue started successfully in 847 milliseconds
          sep-15 12:40:16 JowiHue InitIO:Plugin basic initialisation done
          sep-15 12:40:16 JowiHue Starting plugin JowiHue 2.1.0.0 on Windows
          sep-15 12:40:16 Starting Plug-In Initializing plugin JowiHue ...
          sep-15 12:40:16 Info Plugin JowiHue has connected. IP:127.0.0.1:49584
          sep-15 12:40:15 Plug-In Finished initializing plug-in JowiHue
          sep-15 12:40:06 Info Plugin JowiHue with instance: has disconnected
          Could the errors in the startup explain the problem and if so is there a remedy?
          Regards
          Fredrik
            Here are the log entries from the update yesterday (where some errors are present);
            sep-14 10:57:03 JowiHue ============================================================ ==================================
            sep-14 10:57:03 JowiHue 2 Animations available for use in this plugin
            sep-14 10:57:03 JowiHue 6 Local scenes available for use in the JowiHue plugin
            sep-14 10:57:03 JowiHue 22 Presets available for use in the JowiHue plugin
            sep-14 10:57:03 JowiHue -------------------------------------Plugin info ---------------------------------------------
            sep-14 10:57:03 JowiHue 2 Pressure sensor(s) found on bridge 'Phoscon-GW' with 2 supporting HS device(s)
            sep-14 10:57:03 JowiHue 2 Humidity sensor(s) found on bridge 'Phoscon-GW' with 2 supporting HS device(s)
            sep-14 10:57:03 JowiHue 4 Open/Close sensor(s) found on bridge 'Phoscon-GW' with 4 supporting HS device(s)
            sep-14 10:57:03 JowiHue 1 Daylight sensor found on bridge 'Phoscon-GW'
            sep-14 10:57:03 JowiHue 1 Lightlevel sensor(s) found on bridge 'Phoscon-GW' with 1 supporting HS device(s)
            sep-14 10:57:03 JowiHue 2 Temperature sensor(s) found on bridge 'Phoscon-GW' with 2 supporting HS device(s)
            sep-14 10:57:03 JowiHue 2 Motion sensor(s) found on bridge 'Phoscon-GW' with 2 supporting HS device(s)
            sep-14 10:57:03 JowiHue 8 Remote switch(s) found on bridge 'Phoscon-GW' with 7 supporting HS device(s)
            sep-14 10:57:03 JowiHue Bridge Phoscon-GW is at version 2.5.60 of type deCONZ on a ConBee
            sep-14 10:57:03 JowiHue 12 Groups available on bridge 'Phoscon-GW'
            sep-14 10:57:03 JowiHue 33 lights and/or plugs connected to bridge 'Phoscon-GW'
            sep-14 10:57:03 JowiHue -------------------------------------Bridge info ---------------------------------------------
            sep-14 10:57:03 JowiHue Error: (RefreshDevices):Start:Indexet låg utanför gränserna för matrisen.
            sep-14 10:56:59 JowiHue Initialisation other devices completed correctly
            sep-14 10:56:51 Blue-Iris Successfully logged in to BlueIris server: Götavägen (ver 5.0.2.6) as Fredrik.
            sep-14 10:56:47 JowiHue * Connected to bridge Phoscon-GW at 192.168.2.104:8090
            sep-14 10:56:47 JowiHue Initialisation bridgedevices completed correctly, but needed 2 retries
            sep-14 10:56:40 Starting Plug-In Plugin JowiHue started successfully in 897 milliseconds
            sep-14 10:56:40 JowiHue InitIO:Plugin basic initialisation done
            sep-14 10:56:40 JowiHue Starting plugin JowiHue 2.1.0.0 on Windows
            sep-14 10:56:39 Starting Plug-In Initializing plugin JowiHue ...
            sep-14 10:56:39 Info Plugin JowiHue has connected. IP:127.0.0.1:56803
            sep-14 10:56:39 Warning I/O interface JowiHue is down, executable is not running, restarting ...
            sep-14 10:56:26 Error Calling HSEvent in plugin JowiHue, Instance :Objektreferensen har inte angetts till en instans av ett objekt.
            sep-14 10:56:26 Info Plugin JowiHue with instance: has disconnected
            sep-14 10:56:25 JowiHue problem finding sensor belonging to device at 1128 named Power aborting rename
            sep-14 10:56:24 JowiHue problem finding sensor belonging to device at 1124 named Power aborting rename
            sep-14 10:56:24 JowiHue problem finding sensor belonging to device at 1123 named Power 2 aborting rename
            sep-14 10:56:00 Z-Wave Device: 2 Allrummet Motion Sensor Set to On/Open/Motion
            sep-14 10:55:40 JowiHue Refresh bridge Phoscon-GW set to 30 seconds after establishing direct connection
            sep-14 10:55:39 JowiHue socket opened for Phoscon-GW on 192.168.2.104:20877
            sep-14 10:55:37 JowiHue ============================================================ ================
            sep-14 10:55:37 JowiHue ========== Conversion was succesfull, proceeding normal execution ==========
            sep-14 10:55:37 JowiHue =============== Ending conversion JowiHue devices - step 2 =================
            sep-14 10:55:37 JowiHue ============================================================ ==================
            sep-14 10:55:37 JowiHue =============== Starting conversion JowiHue devices - step 2 =================
            sep-14 10:55:37 JowiHue ============================================================ ==================================
            sep-14 10:55:37 JowiHue 2 Animations available for use in this plugin
            sep-14 10:55:37 JowiHue 6 Local scenes available for use in the JowiHue plugin
            sep-14 10:55:37 JowiHue 22 Presets available for use in the JowiHue plugin
            sep-14 10:55:37 JowiHue -------------------------------------Plugin info ---------------------------------------------
            sep-14 10:55:37 JowiHue 2 Pressure sensor(s) found on bridge 'Phoscon-GW' with 2 supporting HS device(s)
            sep-14 10:55:37 JowiHue 2 Humidity sensor(s) found on bridge 'Phoscon-GW' with 2 supporting HS device(s)
            sep-14 10:55:37 JowiHue 4 Open/Close sensor(s) found on bridge 'Phoscon-GW' with 4 supporting HS device(s)
            sep-14 10:55:37 JowiHue 1 Daylight sensor found on bridge 'Phoscon-GW'
            sep-14 10:55:37 JowiHue 1 Lightlevel sensor(s) found on bridge 'Phoscon-GW' with 1 supporting HS device(s)
            sep-14 10:55:37 JowiHue 2 Temperature sensor(s) found on bridge 'Phoscon-GW' with 2 supporting HS device(s)
            sep-14 10:55:37 JowiHue 2 Motion sensor(s) found on bridge 'Phoscon-GW' with 2 supporting HS device(s)
            sep-14 10:55:37 JowiHue 8 Remote switch(s) found on bridge 'Phoscon-GW' with 7 supporting HS device(s)
            sep-14 10:55:37 JowiHue Bridge Phoscon-GW is at version 2.5.60 of type deCONZ on a ConBee
            sep-14 10:55:37 JowiHue 12 Groups available on bridge 'Phoscon-GW'
            sep-14 10:55:37 JowiHue 33 lights and/or plugs connected to bridge 'Phoscon-GW'
            sep-14 10:55:37 JowiHue -------------------------------------Bridge info ---------------------------------------------
            sep-14 10:55:37 JowiHue Error: (RefreshDevices):Start:Indexet låg utanför gränserna för matrisen.
            sep-14 10:55:32 JowiHue Initialisation other devices completed correctly
            sep-14 10:55:31 JowiHue removed orphaned parentdevice 1541
            sep-14 10:55:22 JowiHue * Connected to bridge Phoscon-GW at 192.168.2.104:8090
            sep-14 10:55:22 JowiHue Initialisation bridgedevices completed correctly, but needed 2 retries
            sep-14 10:55:15 JowiHue Importing SensorModels
            sep-14 10:55:15 JowiHue Importing SensorTypes
            sep-14 10:55:15 JowiHue Importing lampTypes
            sep-14 10:55:14 JowiHue ============================================================ ================
            sep-14 10:55:14 JowiHue =============== replace HSPI_JowiHue.exe with old version!! ================
            sep-14 10:55:14 JowiHue =============== Check the logs and restore HS database ================
            sep-14 10:55:14 JowiHue =============== Errors have occured during conversion! ================
            sep-14 10:55:14 JowiHue =============== Ending conversion JowiHue devices - step 1 =================
            sep-14 10:55:07 JowiHue Error: (ConvertDevices)::Error occured converting dv.name(hs) Kolumnen uniqueid är begränsad till unika värden. Värdet 00:0b:57:ff:fe:24:d4:72 finns redan.
            sep-14 10:54:40 JowiHue ============================================================ ================
            sep-14 10:54:40 JowiHue ============= Starting conversion JowiHue devices - step 1 =================
            sep-14 10:54:40 Starting Plug-In Plugin JowiHue started successfully in 1030 milliseconds
            sep-14 10:54:40 JowiHue InitIO:Plugin basic initialisation done
            sep-14 10:54:39 JowiHue Starting plugin JowiHue 2.1.0.0 on Windows
            sep-14 10:54:39 Starting Plug-In Initializing plugin JowiHue ...
            sep-14 10:54:38 Info Plugin JowiHue has connected. IP:127.0.0.1:56790
            sep-14 10:54:38 Plug-In Finished initializing plug-in JowiHue
            sep-14 10:53:02 Updater Install/Update of package JowiHue was successful.
            sep-14 10:53:02 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\HSPI_JowiHue.exe.config
            sep-14 10:53:02 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\JowiHue\WebSocket4Net.dll
            sep-14 10:53:02 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\bin\JowiHue\Newtonsoft.Json.dll
            sep-14 10:53:02 Updater Extraction Complete.
            sep-14 10:53:01 Updater Extracting files from zip file: JowiHue_images.zip
            sep-14 10:53:01 Updater Warning File exists, not overwriting: C:\Program Files (x86)\HomeSeer HS3\Data\JowiHue\JowiHue.db
            sep-14 10:53:01 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\Config\JowiHueImports.xml
            sep-14 10:53:01 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\html\jowihue\JowiHue.pdf
            sep-14 10:53:01 Updater Copying file: C:\Program Files (x86)\HomeSeer HS3\Docs\JowiHue.pdf
            sep-14 10:53:00 Updater Installing package JowiHue
            sep-14 10:53:00 Updater Update hspi_jowihue.exe downloaded successfully
            sep-14 10:52:41 Updater Downloading update: JowiHue
              Fredrik,
              Do you have a backup of the Homeseer database before installing the new version? As the conversion has been broken with as much alarm the plugin could make:
              If you have the backup, can you pease replace the old version of the plugin (only executable is sufficient) and also the old Homeseer database (Homeseer.hsd under \Data directory).
              Then please set the trace options detailed logging and log to file in the configuration page of the (old) plugin.
              After that, upgrade the plugin again and let it run through the conversion, which probably show you the same errors. Stop the plugin and locate the JowiHue.log file in the Logs subdirectory of your HS installation.
              Send this log file to me (jowihue at ziggo dot nl) and restore the old executable and old Homeseer database again. Wait with upgrading until I found the issue here?
              Wim
              -- Wim
                Normally I don't check the log after a plugin update (that is of course different if the plugin fails to start again...).
                I do have a backup but I'm not sure where I can find an old version of the plugin?
                Regards
                Fredrik
                  Wim, I found the old plugin exe in the backup and you now have the new log file in your mailbox.
                    Is the/my issue resolved in the latest 2.1.0.1 ? As mentioned I only have a problem if I start homeseer and then it works perfectly. So I don't want to make things worse by updating
                      Forgot to mention that indeed. The issue should be gone - as in the plugin should now continue and not restart anymore. There might appear a warning on the log on the device that caused the issue earlier. If you get this line, let me know what it says, so we can take it from there if needed.
                      Wim
                      -- Wim
