how to autostart deConz after reboot?
    I'm not an expert in Linux. I'm trying to set an auto-start of deConz on reboot (after power outage for example). How do I do that?
    I have webmin and have setup a cron job to autostart HS3.
    That's one method. How would I go about doing that for deConz?
    Thanks!!
    Pete
    Anyone? Help, please?
      Depending on how it was installed, the following command may be all you need. This is for the gui version: sudo systemctl enable deconz-gui
      Bill
        Hi Bill, thanks a lot.
        for installation I followed the steps here:
        https://phoscon.de/en/conbee/install#ubuntu
        will this command auto start Deconz in the event of reboot/power outage and so on?
        thanks again,
        pete.
          Yes, that command will hook deconz-gui into starting at boot.
            That didn't work too well.
            Lubuntu freezes on splash screen on reboot.
            Seems to be on an endless loop. On boot, press down arrow - this is the display.
            How to fix?
              Disable the boot startup using sudo systemctl enable deconz-gui, then check logs to see what's causing the hang - maybe you've a port conflict or something?
                Hi. Thanks for the reply. I've no experience with Linux so everything is a challenge. But I have sorted it by creating a cron job on boot in Webmin : systemctl start deconz (rather than enable). I put a sleep on it and a later one for HS3 and it now works seamlessly.
                thanks for all the help.
                  Yeah, the whole linux thing has a steep learning curve, but you'll soon see that there are many ways to skin a cat - your way also works, and that is just as viable as launching it using systemctl.
                  Go with whatever you can get to work
