Will this plugin allow control of the Axis Gear blind control? I'm not sure if the controller needs to support it or the plugin
If this is your first visit, be sure to check out the FAQ. You must register before you can post.
IMPORTANT: Your first post will be checked for appropriate content. This may take a bit of time.
AXIS Gear Device Blinds Name AXIS Gear Label Blinds Type AXIS Gear ST Version Published Zigbee Id 0024460000144F9A Device Network Id 2187 Status ONLINE Hub SmartThings Hub Group Living room Last Activity At 2019-12-20 8:00 AM EST Date Created 2019-12-18 5:33 PM EST Last Updated 2019-12-18 5:48 PM EST Next Hop SmartThings Hub (0000) Data zigbeeNodeType: SLEEPY_END_DEVICE application: 8A endpointId: 01 manufacturer: AXIS model: Gear Raw Description 01 0104 0202 01 07 0000 0003 0006 0008 0102 0020 0001 01 0019 Firmware Current Version: 0x01070500 Target Version: 0x01070500 Last Updated: N/A Last Checked: 2019-12-20 7:59 AM EST - Check Now Current States switch: on battery: 100 level: 100 checkInterval: 7800 windowShade: open supportedWindowShadeCommands: [ "open", "close", "pause" ] Preferences (edit) Name Type Value preset number 100 Execution Location Cloud Events List Events In Use By
