Nothing was happening at the time except for motion sensors being triggered.
Unfortunately the crash trashed the HSD log.
From the windows event log:
Application: HSPI_JowiHue.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException
at System.Runtime.Remoting.Messaging.LogicalCallContext.Propaga teIncomingHeadersToCallContext(System.Runtime.Remoting.Messa ging.IMessage)
at System.Runtime.Remoting.Proxies.RealProxy.PrivateInvoke(Syst em.Runtime.Remoting.Proxies.MessageData ByRef, Int32)
at HomeSeerAPI.IHSApplication.WriteLog(System.String, System.String)
at HSPI_JowiHue.utils.Log(System.String, LogLevel)
at HSPI_JowiHue.DeCONZCache+DeCONZWebsocket.SocketClosed(System .Object, System.EventArgs)
at HSPI_JowiHue.DeCONZCache+DeCONZWebsocket._Lambda$__9-2(System.Object, System.EventArgs)
at WebSocket4Net.WebSocket.FireClosed()
at WebSocket4Net.WebSocket.OnClosed()
at WebSocket4Net.WebSocket.client_Closed(System.Object, System.EventArgs)
at SuperSocket.ClientEngine.ClientSession.OnClosed()
at SuperSocket.ClientEngine.AsyncTcpSession.OnClosed()
at SuperSocket.ClientEngine.AsyncTcpSession.ProcessReceive(Syst em.Net.Sockets.SocketAsyncEventArgs)
at SuperSocket.ClientEngine.AsyncTcpSession.SocketEventArgsComp leted(System.Object, System.Net.Sockets.SocketAsyncEventArgs)
at System.Net.Sockets.SocketAsyncEventArgs.OnCompleted(System.N et.Sockets.SocketAsyncEventArgs)
at System.Net.Sockets.SocketAsyncEventArgs.ExecutionCallback(Sy stem.Object)
at System.Threading.ExecutionContext.RunInternal(System.Threadi ng.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.Execu tionContext, System.Threading.ContextCallback, System.Object, Boolean)
at System.Threading.ExecutionContext.Run(System.Threading.Execu tionContext, System.Threading.ContextCallback, System.Object)
at System.Net.Sockets.SocketAsyncEventArgs.FinishOperationAsync Failure(System.Net.Sockets.SocketError, Int32, System.Net.Sockets.SocketFlags)
at System.Net.Sockets.SocketAsyncEventArgs.CompletionPortCallba ck(UInt32, UInt32, System.Threading.NativeOverlapped*)
at System.Threading._IOCompletionCallback.PerformIOCompletionCa llback(UInt32, UInt32, System.Threading.NativeOverlapped*)
Then:
Faulting application name: HSPI_JowiHue.exe, version: 2.1.0.8, time stamp: 0x5ddbcc8c
Faulting module name: mscorlib.ni.dll, version: 4.7.3460.0, time stamp: 0x5d3a201a
Exception code: 0xc0000005
Fault offset: 0x00435c72
Faulting process id: 0x1330
Faulting application start time: 0x01d5cb70554bb79d
Faulting application path: C:\Program Files (x86)\HomeSeer HS3\HSPI_JowiHue.exe
Faulting module path: C:\Windows\assembly\NativeImages_v4.0.30319_32\mscorlib\3621 7b1d45d00df6811edfed7ec4662e\mscorlib.ni.dll
Report Id: 815a3119-8ca1-4994-a8c5-1ab9a53f6131
Faulting package full name:
Faulting package-relative application ID:
Then computer locked up.......
Now upon reboot I am getting:
Then:
Jan-16 09:04:12 | Info | No device issues found |
Jan-16 09:04:12 | Warning | Device (458) JowiHue Playroom Lamps (CT) does not reference a parent, it should reference one parent |
Jan-16 09:04:12 | Warning | Issue checking child device (458) JowiHue Playroom Lamps (CT) |
Jan-16 09:04:12 | Warning | Device (457) JowiHue Playroom Lamps (Sat) does not reference a parent, it should reference one parent |
Jan-16 09:04:12 | Warning | Issue checking child device (457) JowiHue Playroom Lamps (Sat) |
Jan-16 09:04:12 | Warning | Device (456) JowiHue Playroom Lamps (Hue) does not reference a parent, it should reference one parent |
Jan-16 09:04:12 | Warning | Issue checking child device (456) JowiHue Playroom Lamps (Hue) |
Jan-16 09:04:12 | Info | Checking device parent child relationships... |
