Hello
My setup is running DeConz on same Windows 10 machine as HS3 with a ConBee2 stick and using JowiHue to control my ZigBee devices.
After including three IKEA Fyrtur smartblinds to the system I can not open the list with sensors on bridge and get following error in HS3 log: "Error: (BuildSliderSensors)::web Maintenance:Objektreferanse er ikke satt til en objektforekomst." (Translated last part: Objectreference is not set to an object).
I can also see that I have an mismatch number of sensors on Bridge Maintenance page where it says: "used on this bridge 9 sensors" and later it says "Sensors on Bridge (holding 8 sensors)".
I am almost certain the problem is with the smartblinds from IKEA, and wondering if perhaps it has something to do with the integration of battery level from the blinds. Have deleted(excluded) the three blinds from Zigbee network and everything worked as normal, as soon as i included them again I get the same error.
In the REST-API each smartblind list one light which report "light level" and one sensor which report "battery level". In HS3 only one "light device" is created and it reports the correct position of smartblinds but there are no devices for battery level for the blinds.
Same device in REST-API:
"22":
{ "config": { "alert": "none", "on": true, "reachable": true },
"ep": 1,
"etag": "3b1d294250879693b83656772b707f30",
"manufacturername": "IKEA of Sweden",
"modelid": "FYRTUR block-out roller blind",
"name": "FYRTUR block-out roller blind ",
"state": { "battery": 94, "lastupdated": "2020-03-14T07:56:25" },
"swversion": "2.2.009",
"type": "ZHABattery",
"uniqueid": "14:b4:57:ff:fe:f8:e0:4a-01-0001" }
"19":
{ "etag": "3e085bb2a142a8a3f1bfefc7f9133f82",
"hascolor": false,
"name": "Rullegardin Øst-Nord",
"state": { "alert": "none", "bri": 17, "on": true, "reachable": true },
"swversion": "20190311",
"type": "Window covering device",
"uniqueid": "14:b4:57:ff:fe:f8:e0:4a-01" }
Anybody have a solution for this.
"22":
"ep": 1,
"19":
"hascolor": false,
