The last sensors/switches I have added through deCONZ seems to get some kind of a wrong setup in JowiHue.
I have the same problem with Ikea remote controls, both the round and square ones, and the last Xiaomi door/window sensor I added. Have tried removing, resetting, adding back several times - all with the same result.
After adding them, they seems to be just fine in HS - showing up with only one device which indicates their status perfectly correct. But after a couple of minutes JowiHue is replacing the first device with two new devices; a root device and a battery device, as shown in the screenshot below. As you can see, the device status is gone, but the Root-device seems to be updated with new time stamp when the sensor sends a status update - but it still is "locked" with "No status (Root)".
The three sensors in the screenshot is (from top):
Edit: I forgot to mention it - adding lights (Ikea Trådfri, Philips Hue, Gledopto RGB) work just fine.
- Ikea TRÅDFRI remote control ("square" version, only 0/1).
- Ikea TRÅDFRI remote control ("round" version, like this.)
- Xiaomi window/door sensor (like this.)
