Wrong installation Silvercrest Smart Home Powerstrip with USB
    The "USB-Steckdosenleiste" from SilverCrest as can be acquired at LIDL is not recognised correctly. The first socket is recognised as on/off, the second and third as colour light. The device type is: TS011F.
    All sockets similar to:
    On/Off plug-in unit
    **************************** Object info *****************************
    "type": "On/Off plug-in unit",
    "name": "On/Off plug-in unit 12",
    "modelid": "TS011F",
    "uniqueid": "84:2e:14:ff:fe:52:f0:7c-01",
    "manufacturername": "Heiman",
    "state": {
    "on": true,
    "alert": "none",
    "reachable": true
    "etag": "1c52b3286ec19610f4653e14ca58f192",
    "hascolor": false
    ************************* End Object info ***************************
    First socket:
    TS011F
    Manufacturer: Heiman
    Capabilities: On/Off plug
    Type: On/Off plug-in unit
    Software version:
    Second socket:
    Uniqueid: 84:2e:14:ff:fe:52:f0:7c-02
    Model: Unknown
    Capabilities: Dimmable, Colour temperature, Hue / Saturation, cie colorspace(xy)
    Software version:
    Third socket:
    Uniqueid: 84:2e:14:ff:fe:52:f0:7c-03
    Model: Unknown
    Jeroen,
    On the github the devs are working overtime on the new LIDL devices (even the Christmas tree lights ) It can be that this is still a work in progress at this point for deCONZ.
    I am missing the json part for the other two sockets? Do you see those on the devices. Are all devices created as separated devices or as childs under one parent device?
    Wim
    -- Wim
      The sockets are created as one device with child devices: 3 on/off devices, 1 hue and sat for socket 2 and 1 hue and sat for socket 3.
      I can control all sockets with on/off. When I rename one of the sockets the others are updated automatically.
      In Bridge Maintenance Lights on Bridge I see only socket 2 and 3.
      The JSONs:
      Socket 2:
      On/Off plug-in unit
      "name": "On/Off plug-in unit socket 3",
      "uniqueid": "84:2e:14:ff:fe:52:f0:7c-02",
      "state": {
      "on": false,
      "alert": "none",
      "reachable": false
      "etag": "f013894ee1627078136783f72c9bfb15",
      "hascolor": false
      Socket 3:
      On/Off plug-in unit
      "uniqueid": "84:2e:14:ff:fe:52:f0:7c-03",
      "state": {
      "on": false,
      "alert": "none",
      "reachable": false
      "etag": "79ba3290c5b4cdf44c95780f2f11fc23",
      "hascolor": false
        Jeroen,
        I have received mine this week. Will be testing it to see what is happening here.I think the main issue will be that this is the first powerstrip device presented for the plugin.
        Will be back once I have tested it
        Wim
        -- Wim
          Hopefully you see the same as I do đŸ¤”. Otherwise it becomes really interestingđŸ˜‰
          By the way this power strip is a really nice thing to have.
