No "Bridge maintenance"?
    Team,
    Sorry, this post is now in the HS4 JowiHue forum, where I should have posted it in the first place :-)
    When I go to Bridge Maintenance at http://HS_IP_address/JowiHue/Bridges.html I can see both bridges (hue and conbeeII) but I
    • can't click the Conbee bridge (PhosconDJ-GW)
    • can't click the light/group/sensor info tabs for the first bridge (homehue)
    Restarting HS 4.1.10 used to help but doesn't help anymore.
    Verbose logging shows this info (not sure if it's relevant)
    17:24:59.9468846 -- (BridgePage.GetBridgePage) Debug: preload bridges called
    17:24:59.9468846 -- (BridgePage.GetBridgePage) Debug: selectedfunction: 1 for tab:ECB5FAFFFE1A4BC0
    17:24:59.9468846 -- (BridgePage.GetBridgeActions) Debug: Getting bridge action for homehue ECB5FAFFFE1A4BC0
    17:25:02.4310267 -- (BridgeApi.SendRequest) sendrequest total took 75
    17:25:02.4320268 -- (BridgeApi.GetJsonCommand) Sendrequest took 75 millisconds Thread: 0
    17:25:02.5280323 -- (Mylights.InitialLights) starting for 'homehue'
    17:25:02.6880414 -- (MySensors.InitialSensors) starting for homehue
    Any idea what causes this problem?
    Dirk-Jan,
    Are you using FireFox by any chance? What happens when you use another browser?
    Wim
    -- Wim
      Dirk-Jan,
      Wim
      With another browser it works fine!
        Yes, I hope to find the cause someday. If I try do use the devopers tools in firefox, all I can find is that it to stop on an error in bootstrap code. But I seem not to be able to discover the bootstrap function I am appearantly using on this page
        It must be some different function then what I am using on the other pages... If I'd knew I could try to work around it....
        -- Wim
