Hi,
I'll try to make this not too long as much as possible. Few weeks ago, I had an issue with setting up a Z-Net with HS4 and learned this device is a Raspberry Pi. I just became very interested in those little beasts which allowed me to find the deCONZ RaspBee gateway. A few more search and discovered the JowiHue plugin supported that gateway. Wow! 2 years after installing heated floors in my house, and stucked with internet dependant Zigbee thermostats (I'm still searching for Z-Wave thermostats with NTC sensor that would work with HS) I could see a possibility to control them with HS.
I first made sure deCONZ supported my thermostats, Sinopé TH1300ZB. They are: https://github.com/dresden-elektroni...in/issues/1289
So, got the kit, put it together, setup a fixed IP, update firmware, etc. I was then able to pair one of the thermostat to deCONZ and it has most of the characteristics seen in the link above. That's when progress kinda stopped. The Phoscon app does not seem to be able to add or see thermostats. Looks like it only supports lights, switches and sensors.
The 'general.xml' file in /usr/share/deCONZ/zcl does reference the TH1300ZB, which is probably why I was able to pair one. So I turned to the plugin, installed it in HS4. It discovered the RaspBee 2 on the first shot, almost instantaneously. Scanned for devices, no thermostat. HS4 does show the deCONZ controller as well as the plugin 'All Lights', but that's it.
Searched a bit more and found the REST api doc implemented in deCONZ. I can talk to it no problem. But it doesn't see the thermostat either. Jowi will confirm, but I'm guessing the plugin talks to the REST api, probably the same for the Phoscon app.
I must have missed something somewhere, most likely a simple stupid thing. I realize this is more a deCONZ than a Jowi plugin issue but I haven't been able to find a forum related to deCONZ
So, the question is what did I missed and how do I get the REST api and the Jowi plugin to see and talk to the thermostat?
I look forward to using the Jowi plugin and buy it before the trial period ends. It tells me there is 23 days left on the trial.
G.
G.
