I am adding the Sinope Smart Plug & Smart Controller (ZigBee) RM3250ZB & SP2600ZB
I have added the devices in Phoscon app. The devices and all their clusters are populated in deCONZ. I can communicate and control/read the clusters/data via deCONZ. The issue is that JowiHue, imported the device as an on/off device with only on/off as a command. It doesn't import any of the other clusters. I want to see the live amperage/wattage/voltage readings found in the Electrical Measurement & Simple Metering Cluster.
In regards to REST-API, it brings up only on/off (what is in Phoscon).
So the question is can we get the device's clusters/ their data points imported with the device so that we are able to see all the relevant data points from within JowiHue, or will it only take the core (switch) device from Phoscon and none of its attributes.
