Axis Gear Issue
    Axis Gear Issue
    I have a number of Axis Gear Shade Controls (https://helloaxis.com/products/axis-gear). About every 5 Minutes this happens on one of them the "on" and "bri" state changes causing it to incorrectly display the status in HS without the shade moving. I can change the reporting for the "on" state in deconz but it will get over written and return to the 1/300. The lift state is always correct. I know this isn't your issue but is there anyway in JowiHue that device will only follow the status of the "lift" value or is there anything else I can do to fix this.
    Incorrect:
    "state": {
    "bri": 254,
    "lift": 0,
    "on": true,
    "open": true,
    "reachable": true
    Correct:
    "state": {
    "bri": 0,
    "lift": 0,
    "on": false,
    "open": true,
    "reachable": true
    I will check if I can change the state reporting the lift values instead. Not sure if this is an easy one, if it is I will change it.
    -- Wim
      That would be great. Let me know if you need anything from me.
        Wim,
        Ever since the last update my Blinds are working great! Thanks for your help!!
          Thanks for confirming!
          -- Wim
