I'd like to move my Conbee2 dongle and deCONZ setup from a windows 10 machine to a raspberry pi 3b running Raspbian jessie.
Any tips/warnings/horror stories I should know about?
I'd like to avoid re-doing all my devices; both in deCONZ and in HS3. If I'm running the same version of deCONZ should I just be able to backup/restore the database and have everything 'work the same as before'?
I'd be moving the deCONZ setup to a different IP. I don't see a place the plug-in UI to change the IP address. Is there a config file I could change? I see a C:\Program Files (x86)\HomeSeer HS3\Data\JowiHue\Jowihue.db file, but an SQLite editor doesn't show an IP associated with the Phoscon bridge.
