Aqara vibration sensor has doubled devices?
  • w.vuyk
    It should do this on its own. I have experimented with it myself to, but without much clarity. I could bounce it quit hard and the value did not really make much sense on the force. It would have been helpfull if it was more clear if you could distinguish between brute force or just a smooth move. Long time since I looked into this, now mainly using the movement indicator only on my dryer.
  • wkearney99
    How does the Vibration Strength value function? I can see that the Movement state for Vibration changes, and the orientation angles. But the strength value seems to be staying the same, even after the Movement state turns off.
    That is, if I bump, bang or drop the sensor onto the table I can see that the Vibration Strength value changes (most of the time). But it never seems to settle back down to a lower value.
    Is there a way to reset the vibration strength value? Or should it be doing so "on it's own"?
  • w.vuyk
    I noticed a similar situation a while ago, It happens when the device gets created the first time by deCONZ. When it creates a new device, it sends a notificiation to the plugin. But lately I noticed that deCONZ sends a double "new" notification. This issue should already be resolved in the HS4 version of the plugin, I will also check this for the HS3 version of the plugin.
    Once the device is created in deCONZ you can delete (exactly what you did) the device in HS and restart the plugin to let the single device be created.
    Wim
  • wkearney99
    started a topic Aqara vibration sensor has doubled devices?
    I just attempted to connect an Aqara vibration sensor to HS3 via a Conbee2/deCONZ gateway.
    I used the plug-in to scan and it paired. I see a root device... but then some doubled children devices?
    JowiHue JowiHue Vibration (2750),
    JowiHue JowiHue Orientation X (2751),
    JowiHue JowiHue Orientation Y (2752),
    JowiHue JowiHue Orientation Z (2753),
    JowiHue JowiHue Tilt angle (2754),
    JowiHue JowiHue Vibration Strength (2755),
    JowiHue JowiHue Position (2756),
    JowiHue JowiHue Battery Vibration 33 (2757),
    JowiHue JowiHue Vibration (2758),
    JowiHue JowiHue Orientation X (2759),
    JowiHue JowiHue Orientation Y (2760),
    JowiHue JowiHue Orientation Z (2761),
    JowiHue JowiHue Tilt angle (2762),
    JowiHue JowiHue Vibration Strength (2763),
    JowiHue JowiHue Position (2764)
    This from the Jowihue tab on the root device:
    ZHAVibration
    **************************** Object info *****************************
    "config": {
    "battery": 100,
    "on": true,
    "pending": [],
    "reachable": true,
    "sensitivity": null,
    "sensitivitymax": 21,
    "temperature": 3500
    "ep": 1,
    "etag": "fe961c1afe621c2991d447a6efdddb87",
    "lastseen": "2021-06-04T22:03Z",
    "manufacturername": "LUMI",
    "modelid": "lumi.vibration.aq1",
    "name": "Vibration 33",
    "state": {
    "lastupdated": "2021-06-04T22:04:30.027",
    "orientation": [
    1,
    -1,
    89
    "tiltangle": 15,
    "vibration": false,
    "vibrationstrength": null
    "type": "ZHAVibration",
    "uniqueid": "00:15:8d:00:05:cf:c3:3b-01-0101"
    ************************* End Object info ***************************
    This from the device list:
Name:	2021-06-04 18_16_25-HomeSeer Web Control.png
    deCONZ seems to think it's a door lock?
Name:	deconz vibration 33.png
    I manually selected all of them and deleted them. Then I stopped the Jowihue plug-in. Then I restarted deCONZ, and then restarted the plug-in. This time it only created one set of devices.
    No idea why it created duplicates the first time.
