I just attempted to connect an Aqara vibration sensor to HS3 via a Conbee2/deCONZ gateway.
I used the plug-in to scan and it paired. I see a root device... but then some doubled children devices?
This from the Jowihue tab on the root device:
This from the device list:
deCONZ seems to think it's a door lock?
I manually selected all of them and deleted them. Then I stopped the Jowihue plug-in. Then I restarted deCONZ, and then restarted the plug-in. This time it only created one set of devices.
No idea why it created duplicates the first time.
JowiHue JowiHue Vibration (2750), JowiHue JowiHue Orientation X (2751), JowiHue JowiHue Orientation Y (2752), JowiHue JowiHue Orientation Z (2753), JowiHue JowiHue Tilt angle (2754), JowiHue JowiHue Vibration Strength (2755), JowiHue JowiHue Position (2756), JowiHue JowiHue Battery Vibration 33 (2757), JowiHue JowiHue Vibration (2758), JowiHue JowiHue Orientation X (2759), JowiHue JowiHue Orientation Y (2760), JowiHue JowiHue Orientation Z (2761), JowiHue JowiHue Tilt angle (2762), JowiHue JowiHue Vibration Strength (2763), JowiHue JowiHue Position (2764)
ZHAVibration **************************** Object info ***************************** { "config": { "battery": 100, "on": true, "pending": [], "reachable": true, "sensitivity": null, "sensitivitymax": 21, "temperature": 3500 }, "ep": 1, "etag": "fe961c1afe621c2991d447a6efdddb87", "lastseen": "2021-06-04T22:03Z", "manufacturername": "LUMI", "modelid": "lumi.vibration.aq1", "name": "Vibration 33", "state": { "lastupdated": "2021-06-04T22:04:30.027", "orientation": [ 1, -1, 89 ], "tiltangle": 15, "vibration": false, "vibrationstrength": null }, "type": "ZHAVibration", "uniqueid": "00:15:8d:00:05:cf:c3:3b-01-0101" } ************************* End Object info ***************************
