Hi. Upgraded from HS3 to HS4 over the weekend and it has gone reasonably well. Upgraded Jowihue plugin to HS4 version at same time as I wanted to get back on improvements track. I read your directions on the cutover and made backup etc before letting rip. No major issue but I’m getting some warnings at start-up. I’d just like to make sure they are not hiding some major issue that may be in the future and would like to know how to tidy these up. I’m not sure how I’m supposed to delete the device holding the ref 0 feature or if this is valid.
Warnings are as follows just after connecting to a Philips hue bridge and Phoscon-GW:
I note each item lies as a feature(?) within the root device which seems to be the one which it is advised to remove (and therefore remove both devices?). See below as an example
And features of same expanded out (is item 4 – function? – separate from the device listed above and the item it is suggested I remove. How will I be able to turn off if that is the case?).
I’ve got a verbose log if that sheds any light. Let me know if you want me to send. Currently running HS Pro Edition 4.2.0.8 on Windows 10 Pro (10.0.19401) as HS platform. JowieHue plugin version is 4.0.4.10.
Thanks.
Thanks.
