JowiHue release 1.0.4.7
  • JowiHue release 1.0.4.7
    -- Wim
    Thx for the update.
      I get this erros in the control window of HS:
      6-11-2014 01:19:11 ~!~JowiHue~!~Error UpdateDevices: Fuglelys
      16-11-2014 01:19:11 ~!~JowiHue~!~Error UpdateDevices: The given key was not present in the dictionary.
      What to do?
        Jakob,
        Any chance that what you are seeing is also in this post?
        If so, it will be resolved in the next release. I would like to know what type of device "Fuglelys" is. You could see it in the properties of the device.
        Wim
        -- Wim
          LLC012 ??
          Jakob,
          Wim
            Originally posted by Jakob.Sand View Post
            LLC012 ??
            Ok. indeed a light that is not yet known to the plugin. I did collect as many types as possible, but Philips is having quite a range and probably will add more.
            The new version will mention the unknown type and not complain after that.
            I am hoping the new version will be available this week.
            Wim
            -- Wim
              ok. I think it is called Bloom. http://www2.meethue.com/en-xx/the-ra...gcolors-bloom/
              Wim
                Jakob,
                There is a new build available. Although it is beta, for windows you can consider this as a normal release as the beta is for Linux. It solves the issue with missing lights for you.
                Wim
                -- Wim
                  i created a scene as you can see in the dump and it seems to hang still there writing "Geeeting Scene details".
                  any idear?
                    any idear?
                    Jakob,
                    I have no idea yet on what is happening here. Would it be possible to send me the database, so I could have a look at what is causing this issue. You can send it to me by PM.
                    Will see if I can catch this bug.
                    Wim
                    -- Wim
                      it is now clear what caused this issue. The plugin does not handle the '%' sign well. So try to avoid using this '%' character in the name of Scenes or Animations!
                      I will try to catch this bug for thee next release (will be a few weeks though).
                      @Jakob, I have returned your database with this scene repaired.
                      Wim
                      -- Wim
                        I have 2 bridges to test
                        It is definitely something I need from the plugin. Let me know if I can help test.
                        Philip
                        pabbott@cpak.com
                          Philip,
                          Thanks for offering to test, I have send you a email just now with some more information. I do have a working version now and would really need some one else to test it.
                          Wim
                          -- Wim
