Unable to install
  • Unable to install
    Hi all,
    I'm migrating my HS3 setup to a new machine and when I try to install the JowiHue plugin, I get this error message in the logs:
    Jan-23 11:01:36 PM Updater Error Installation of package JowiHue failed. Try disabling the plugin first, then re-try the update.
    Jan-23 11:01:36 PM Updater Error Unable to open install.txt file for update C:\Program Files (x86)\HomeSeer HS3\Updates3\JowiHue1.0.5.4
    Jan-23 11:01:36 PM Error Error unzipping C:\Program Files (x86)\HomeSeer HS3\Updates3\JowiHue1.0.5.4\JowiHue_1_0_5_4.zip, Wrong Local header signature: 0x4F44213C on line 0
    When I look at the zip folder, its completely empty. Did something not upload correctly to the HS server?
    I've completely uninstalled and re-installed HS3 with no change.
    I'm running Win 8.1
    Thanks!
    Eliav
    Eliav,
    Yesterday a new version of the plugin was published. Unfortunately the zip file that is used is a corrupted one. I am waiting for HST to correct it. So the issue is not on your side
    As it is weekend now, it might last till Monday.
    Sorry for that,
    Wim
    -- Wim
      Eliav,
      The download issue is resolved. I made a mistake with the dots. You can now correctly install the plugin.
      Wim
      -- Wim
