Stop af light setting with long transition time
    I wish to sloooowly over 5-10 min. reduce (BRI) lights and then when a PIR goes in the room turn BRI to 100% (240)
    How do I cancel a transition going on ?
    Jakob,
    Never really tested it, but qouting the Philips API it should stop by just sending the command to set bright to 254 or 240? Any command should stop transitions. I have an animation stretched in time (to sunset) where sometimes the commands are send faster as the transitiontime. What I think seeing is that the new command takes over the transition.
    Did you experience different? In that case I will test the same here, as I always assumed the API documentation would be correct, but never checked it for real.
    Wim
    -- Wim
